    Video signal too wide on CRT using RGB-Pi
    signal too wide crt rgb-pi
    • boquetipo
      boquetipo last edited by boquetipo
      Hi!
      I have recalbox 4.0.3 standard version with HDMI, and 4.0.0 modified version for RGB-Pi on a CRT TV (that's the purpose of the cable).
      There are no problems with 4.0.3. So far so good. But the video signal of the 4.0.0 RGB-Pi version is too wide for the TV. I talked to the RGB-Pi creator and told me to enter service mode (Thomson TX807CS). Somehow I did it, and I managed to center image and resize height, but there is no option for the width. I'll try to contact with Thomson technical service in a few hours to ask them.
      Edited: I talked to technical service and told me that my TV has no width correction.
      Anyway, is there any option on recalbox/retroarch/ES in order to resize output video signal?
      Thanks.
        Substring @boquetipo last edited by
        @boquetipo Hi
        Have you tried using overscan ?
        101.4k
