    Password/encrypt sd card
    Your recalbox
    passwordencrypt card
    2442
    • gigante154
      gigante154 last edited by
      Hi, it is possible to insert a password / encrypt the sd card to prevent anyone could edit and copy the files (bios, roms, confs ...)
      Thanks.
        paradadf Staff last edited by paradadf
        Nope, not possible. And I really hope you are not planning to sell recalbox!
        gigante154 1 Reply Last reply Reply Quote 0
        • ian57
          @paradadf +100000
          • gigante154
            gigante154 @paradadf last edited by
            @paradadf Oh ok. I'm not planning, It's just for nobody mess all the dedication of organizing the roms or configuration
            Thanks 🙂
              voljega Banned @gigante154 last edited by
              @gigante154 you can juste deactivate the menu then
                Deactivates the web-manager, secure your samba share and modify your root password.
