    Rumble does not stop on PSX Games with Xbox 360 Corded controller Recalbox 4.1
    rumble does stop xbox 360
    • kelv
      kelv last edited by
      Hello Everybody
      How are you?
      I updated to Recalbox 4.1 and it seems that on PSX for some games as Bushido Blade or Enhander, the Xbox 360 corded controller is rumbling with no stop. Please, Does anybody know how to disable rumble on PSX emulator?
      THX
      Kind Regards.
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        Substring @kelv last edited by
        @kelv Hi
        I guess you can do it in retroarch core specific options, but can't tell you where exactly right now
        kelv 1 Reply Last reply Reply Quote 0
        • kelv
          kelv @Substring last edited by
          @Substring I was reading for some config files and so. I didn't find any specific config so finally I decided to go for the graphical Retroarch menu in game and after getting out, the issue is fixed.
          Several tests let me notice that If I get into retroarch in game menu is fixing the issue 🙂 . So as a temporally work around it works 🙂
          THX
          Kind Regards
            Substring @kelv last edited by Substring
            that's a fix we could include if it's a core option
            i'm saying bulls**ts ... the core needs to be patched
