    AV out does not work when starting game
    does starting
    3784
    • sviesusis.alus
      sviesusis.alus last edited by
      Howdy.
      Just made my GBC with PI 2. Turned on AV out for Recalbox. When in menu screen works without any problem, but when trying to launch a game it blinks and goes off. Switched off all smooth functions as per https://github.com/recalbox/recalbox-os/wiki/Connect-your-recalbox-to-a-CRT-with-composite-(EN) , but still no luck. Any suggestions where start to debug ?
        Substring @sviesusis.alus last edited by
        @Justas-Pranskaitis which systems don't work ? have you tried the default NES games for example ?
        sviesusis.alus 1 Reply Last reply Reply Quote 0
        • sviesusis.alus
          sviesusis.alus @Substring last edited by
          @Substring unable to launch SNES systems. Well at least with the one that is in default package of Recalbox 4.0
            @Justas-Pranskaitis is that the only faulty one ?
            • sviesusis.alus
              @Substring yes. Added few more SNES games. tried them. no good. Screen goes blank right after opening the game.
                @Justas-Pranskaitis which reclbox version are you running ?
                • sviesusis.alus
                  @Substring currently 4.0 . First attempt was with 4.1, but latest version acts even stranger. Several times after simple restart got all the configs and data wiped out so downgraded to 4.0
                    @Justas-Pranskaitis could you run /recalbox/scripts/recalbox-support.sh and upload somewhere the generated archive ?
                    • sviesusis.alus
                      @Substring here you go https://www.dropbox.com/s/v68uy2p7xw9vbkh/recalbox-support-20170220181908.tar.gz?dl=0
