    Solved 32X doesn´t work after upgrade
    32x doesn´t upgrade
    • jsianes
      jsianes last edited by
      I upgraded yesterday my Recalbox RPI3 set to latest stable version. Now, 32X emulator doesn´t work. Black screen when trying to launch any game (some of them already tested and working with previous version).
      Detail:
      • Recalbox version: 4.0.1
      • Emulator/Core: Default (trying using LIBRETRO/PICODRIVE with same results)
      • Kernel version: Linux RECALBOX 4.1.19-v7 #1 SMP Wed Jan 25 14:52:49 UTC 2017 armv7l GNU/Linux
        Substring @jsianes last edited by
        @jsianes black screen then back to ES ? or frozen on the black screen ?
        No emulator had any update, so this is confusing ...
        jsianes 1 Reply Last reply Reply Quote 0
        • jsianes
          jsianes @Substring last edited by
          @Substring frozen in black screen and if you press hotkey and start back to ES.
          • jsianes
            jsianes last edited by jsianes
            Trying another romset, it works. But 'faulty' rooms worked great with 4.0.0 version. So, this should be any kind of incompatibility with the last emu version.
            Edit: The blackscreen issue is reproducible also playing 32X games. Just try to play two times Virtua Racing Deluxe. The first time works and the second doesn't.
            • jsianes
              Issue resolved. It seems a video configuration issue in recalbox.conf after upgrading. Details here.
              Everything sorted out. You can mark this thread as resolved.
