    Unsolved Custom Python Lib integrieren
    python lib integrieren
    3300
    • finncyr
      finncyr last edited by
      Hallo zusammen,
      gibt es irgend eine Methode um eigene (benötigte) Python Bibliotheken hinzuzufügen?
      Bräuchte um mein Monochromes Display ansteuern zu können eine Adafruit Bibliothek, der Rest hat alles geklappt, es würde nur noch die Lib fehlen.
      Vielen Dank schon mal
        Substring @finncyr last edited by
        @finncyr Moin !
        I'm afraid no one can answer you in German for such a topic. You wish to install some Python libraries ?
        finncyr 1 Reply Last reply Reply Quote 0
        • finncyr
          finncyr @Substring last edited by
          @Substring Yes, I would like to include a Adafruit Library to connect a little LCD Display. Is this possible?
            @finncyr depends on how the library looks like. If it's a simple .py, easy. If it's a setup.py, should work too I think, but you'd need to make / writable first. Any doc to that library ?
            finncyr 2 Replies Last reply Reply Quote 0
            • finncyr
              @Substring I think it is a setup.py, gonna try it out later
              • Nachtgarm
                Nachtgarm last edited by Nachtgarm
                I moved the topic to international
                • finncyr
                  @Substring
                  error: Setup script exited with error: command '/share/host/usr/bin/arm-buildroot-linux-gnueabihf-gcc' failed with exit status 1
                  The Link to the used Lib is: https://github.com/adafruit/Adafruit_Python_SSD1306
                    @finncyr oh d**n ... You can't add it by yourself as it requires gcc, and gcc is not included in Recalbox. I'll have to read through the script you provided and see if the setup can be avoided
