    Problem screen resolution
    3686
    • ayubius
      ayubius last edited by
      Hi. I have a problem with the screen resolution of the TV. The default is 1920x1080 but the TV only supports 1360х768. Tell me how can I change the resolution under the screen of my TV?
      old game school forever
        paradadf Staff last edited by
        https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        nubirro 1 Reply Last reply Reply Quote 0
        • ayubius
          the problem I have is that I installed it to the hard disk in the computer like the OS and the computer hooked televizornaya. I can't find and edit the configuration file, which is located in the boot
            paradadf Staff @ayubius last edited by
            @ayubius recalbox x86 hasn't been released yet (but soon), so you must have installed a fork. We don't give any support, if you don't use our product 😉
            • nubirro
              nubirro @paradadf last edited by
              @paradadf Hey bro, this link tells us to change boot\config.txt where do we found this?
                paradadf Staff last edited by paradadf
                that's the address... /boot/config.txt XD
                just hold shift while booting 😉
                • nubirro
                  nubirro last edited by
                  Oww! I have to change it on the console?! That's the reason i wasnt doing right...
                  • ayubius
                    where to download the file recalbox.img.gz for flash?
                    https://github.com/recalbox/recalbox-os/wiki/Installation-(EN)#burn-on-a-sdcard-or-an-usb-key-from-an-image-file
