    CouchPotato/Downloads?
    MediaCenter & Dualboot
    kodi couch potato torrents downloads
    • Dan Castle
      Dan Castle last edited by
      Hi,
      I am very new to using Recalbox, just a couple days.
      How do you manage downloads from within recalbox or Kodi?
      Would CouchPotato be an option? If so, any guidance on this?
      What I would like is to have everything done from within the same boot (Kodi boots automatically, in fact) instead of having to use another machine to handle the downloads.
      Any help?
      Thanks!
      • DjLeChuck
        DjLeChuck last edited by
        Hi @Dan-Castle ,
        The recalbox does not provide any build-in solution to manage downloads. You must use your computer and then put your files on your recalbox.
        • Dan Castle
          In my case I download to an external NAS, and recalbox/Kodi is successfully connected to it and showing content.
          What I'd like is to have everything in the same device, without needing an external computer for downloads.
          DjLeChuck 1 Reply Last reply Reply Quote 0
          • DjLeChuck
            DjLeChuck @Dan Castle last edited by
            @Dan-Castle It's not possible out of the box, you need to install some tools by yourself. Search on the forum, someone as installed Transmission on his recalbox.
              Recalbox was never meant to be a bittorrent node ...
