    Castlevania: Harmony of dissonance crashes Recalbox
    Emulator Arcade/PC/Console
    castlevania harmony dissonance crashes recalbox
    • sergioad
      sergioad last edited by
      Hi friends I came to advice that the Gameboy Advance game Castlevania: Harmony of dissonance crashes Recalbox enterely, when you start it it runs as normal but when you reach the menu after pressing start or in the intro sequence the entere Recalbox freezes and you can not press hotkey + start to get put leaving you with the need of forcing a reboot unpluging the power source and pluging it back
      DjLeChuck 1 Reply Last reply Reply Quote 0
      • DjLeChuck
        DjLeChuck @sergioad last edited by DjLeChuck
        @sergioad Hi,
        Maybe by changing the default emulator/core?
        Similar problem here: https://forum.recalbox.com/topic/2522/castlevania-aria-of-sorrow-stalls-game-boy-advance/3
        • sergioad
          Thank you very much, I will change it and try again ☺ and by the way this problem has never occurred me on RetroPie (two months ago I was a RetroPie user) with mgba, I suggest to the devs to check what happends and if it is posible fix it for Recalbox 4.1 I will thank you a lot 😀
