    USB memory stick wont work
    usb memory stick wont
    4316
    • supertom029
      supertom029 last edited by
      my Usb memory stick wont be used, the data wont be put on to it and its brand new
      • DjLeChuck
        DjLeChuck last edited by
        Hi,
        Your USB is formatted in FAT32? What did you mean by "data wont be put"?
        • supertom029
          when I change the memory to it nothing happens it resets but no data put into the stick and the memory is the same
          • DjLeChuck
            What's your recalbox version and which Pi are you using?
            • supertom029
              4.0 and raspberry pi 2
              • supertom029
                if it helps my usb stick is a Toshiba make
                • supertom029
                  I have another memory stick that works but its only 4g and my new one is 64g
                  DjLeChuck 1 Reply Last reply Reply Quote 0
                  • DjLeChuck
                    DjLeChuck @supertom029 last edited by
                    @supertom029 Have you format it in FAT32 as requested?
                    • supertom029
                      I will try that now
                      • supertom029
                        thank you
                        • DjLeChuck
                          @supertom029 It works? 🙂
                          • willieaames
                            willieaames last edited by
                            Does anyone use this in their bartop with the ipac-2 as a USB controller interface?
                            DjLeChuck voljega 2 Replies Last reply Reply Quote 0
                            • DjLeChuck
                              DjLeChuck @willieaames last edited by
                              @willieaames if you have a problem please create another topic 🙂 But maybe this can help you: https://github.com/recalbox/recalbox-os/wiki/Keyboard-encoder-configuration-(EN)
                                voljega Banned @willieaames last edited by
                                @willieaames yeah USB hardrive + ipac2 directly on raspberry pi3 without hub and it works
