    Solved Any way of hiding other systems when making a Bartop
    hiding systems making bartop
    5858
    • creaturefactory
      creaturefactory last edited by
      I was wondering if I would be able to hide the emulators currently on recalbox for a Bartop arcade machine. To just have arcade games visible in the main menu when selecting a game? I'm working on a bartop arcade and would only want to play arcade games no home consoles.
        voljega Banned @creaturefactory last edited by
        @creaturefactory just remove the roms from those systems and they won't show.
        And before you ask no it's not possible to start directly in the arcade system view 😉
        creaturefactory 1 Reply Last reply Reply Quote 0
        • creaturefactory
          creaturefactory @voljega last edited by
          @voljega Ha lol thanks man 🙂
          • lackyluuk
            @creaturefactory It seems that the boot into a specific system game list is possible in one of the next releases 🙂
            • steveb83
              steveb83 last edited by
              Hi, I had the same predicament, so for example I'd set mine up with a fully scraped N64 list, however I'm no longer wanting to see them (mostly use an arcade stick rather than pad).
              So, in the share\roms directory, I renamed the folder 'n64_' and created an empty folder called 'n64'.
              Should I ever want to quickly see the N64 games, I will just rename the folder back to 'n64'. This way I don't need to re-transfer roms \ mess with scraping etc.
              Hope that helps!
              • creaturefactory
                creaturefactory @steveb83 last edited by
                @steveb83 will try it out thanks
                101.4k
