    Problema com Monitor.
    Recalbox geral
    problema com monitor
    5063
    • Murillomc
      Murillomc last edited by
      Pessoal uma dúvida rápida, arrumei um monitor Samsung modelo 2033SW e a resolução dele e 1600x900 ligado via VGA com um adaptador que conecta no raspberry via HDMI e tem uma entrada VGA que recebe o cabo VGA do monitor, mas mesmo configurando no começo escolhendo Modo e Grupo que no caso seria Grupo 2 (CEA) e Modo (83 1600x900) não está ficando certa a imagem, esta fora da tela, a tela não está centralizada e o background fica duplicado como se a resolução fosse menor. gostaria de uma ajuda se alguém já passou pelo mesmo problema.
      Aguardo Respostas.
        Substring @Murillomc last edited by
        @Murillomc Hi
        I don't speak portuguese, but i think you'll find your answers here
        Murillomc 1 Reply Last reply Reply Quote 0
        • Murillomc
          Murillomc @Substring last edited by
          @Substring
          I tried to do this mode but I can not put my monitor in 1600x900
            Substring @Murillomc last edited by Substring
            @Murillomc i guess tha DMT 83 didn't work ? you may give a try to hdmi_cvt=1600 900 60 in your config.txt and comment hdmi_drive and hdmi_mode. If it ever works, take care of the global.videomode in recalbox.conf
            Edit : try in fact :
            hdmi_group=2
            hdmi_mode=87
            • Murillomc
              @Substring
              I'll try that way you said it, but the global video mode in recalbox.conf would have to be made what modification?
                @Murillomc Read the wiki 😉 It depends whether your screen supports 720p or not. If not, set global.videomode to default
                Take also care for N64 which has a special resolution too
                • Murillomc
                  @Substring I tried all the options and the monitor does not get 1600x900 resolution in the config files and in the recalbox.conf and nothing works, there must be some way the monitor can get that resolution.
                    paradadf Staff @Murillomc last edited by
                    @Murillomc I recommend you to double-check if your hdmi-to-vga adapter is up to the task. The very first one I bought only managed to display an old (low resolution) camera on the screen, but not my laptop's screen, even less my pi.
                    With my current one, I didn't need to change anything on the config.txt.
                    • Murillomc
                      Murillomc @paradadf last edited by
                      @paradadf Você tem alguma marca para me indicar, senao vou tentar encontrar um de boa qualidade para fazer o teste pq ja tentei de tudo e olha que eu conheço bem de recalbox. Rs
                      Mas obrigado pela atenção, vou olhar um agora para comprar.
                        @Murillomc this model DIDN'T work for me:
                        http://s.aliexpress.com/MJzeQRvy
                        The model I'm using looks like this:
                        http://s.aliexpress.com/yIV7zIru
