    PSX extension
    psx extension
    4897
    • raulval82
      raulval82 last edited by
      Hi! Is possible to change .bin extension to .cue extension? is better because many of the games that you can find have some .bin files for music, etc... Thanks in advance!
      • hstampfl
        hstampfl last edited by
        Hmm... Couldn't that be an enhancement to have this in the emulationstation menusettings per emulator? I know, that would be a big enhancement and needs more time to implement this.
        I started my retro passion in 1985 with my C64.....Today I have a small (retro) console collection including NES, SNES, N64, GC, Wii, WiiU, GB, GBC, GBA, NDS, DSi, 3DS, 3DS XL, 2DS, NEW 3DS, SMS, SMD, SG, SD, XBOX, XBOX360, XBOX ONE, PSone, PS2, PS3, PS4, PSP, PS VITA, VECTREX, C64, AMIGA 600, MIST Board, Turbo Chamäleon
        • digitaLumberjack
          Hi. Most of psx roms are either in .cue + .bin or .iso. I never use uncompressed iso for ps1. Make isos and you won't have this problem anymore.
          Hmm… Couldn’t that be an enhancement to have this in the emulationstation menusettings per emulator? I know, that would be a big enhancement and needs more time to implement this.
          I try to keep recalboxOS simple. If i add every settings possible in emulationstation, it will be very hard for a new user to understand what to do. Let's use the convention on this one, and 99% of roms are in iso and bin/cue...
          • energizer
            energizer last edited by
            you can convert .bin + .ape audio files (sometimes .bin audio files) in a single iso with isobuster (tutorial on emuparadise)
            • raulval82
              I was only asking to being able to change it in a config file, not in emulationstation... Changing an extension is 2 min, converting all my games... 1 day??
              • digitaLumberjack
                .cue are already supported in psx configuration. You want to remove .bin ? If so you can edit /root/.emulationstation/es_systems.cfg But it will be overwritten at each update.
                • raulval82
                  Thank you!!
                  • colking
                    colking last edited by
                    hey, I'm having trouble getting psx rom working. I can load certain games ie) blades of steel but I can't the the hockey players on the ice, just a black screen with numbers skating around. It also flashes saying no bios found at the beginning of the loading the game(s). Some are img, ccd, or bin extensions. I was just dropping them into the psx folder. Is there something else I have to do with the bios? thanks
