    N64 button missing
    GamePad/GPIO/USB encoder
    button missing
    • Retrofreak
      Retrofreak last edited by
      Hello everyone!
      Just finished installing recalbox 4.0 on my raspberry pi 3, and so far so good... The only issue I've been having is that in the N64 emulator there's one button missing in my controllers (specifically the "Z" button).... For example, if i'm playing goldeneye, there's no button to shoot (even though I push all of the buttons, i cannot shoot)! I'm using 360 wired controllers and the left triger and right triger (LT and RT) don't do anything, what am I missing?
      I've already enabled xboxdrv driver and disable psx driver in recalbox.conf...
      This wiki article seems helpful: https://github.com/recalbox/recalbox-os/wiki/Configure-N64-controllers-(EN), but it doesn't let me overwrite the file, it says that the file is "read-only" or something like that...
      Help me!
      Thank you very much!
        Z is mapped to L2
        Retrofreak 1 Reply Last reply Reply Quote 0
        • Retrofreak
          Retrofreak @Substring last edited by
          @Substring Thanks! I'll do the maping with that in mind so it can work... any ideas of why it doesn't recognize the LT and RT triggers?
          Thanks!
            Substring @Retrofreak last edited by
            @Retrofreak it does recognize them. What happens is a bug when triggers are analog, but you can correct that before confirming
            101.4k
