    Connect External USB ports
    GamePad/GPIO/USB encoder
    connect external usb ports
    • Anonpebbles
      Anonpebbles last edited by Anonpebbles
      Hey all I have recently bought a case to build into a console and I am having an issue connecting the USB ports on the front of the case. To my knowledge these attach to the motherboard of a PC, but obviously I can't do that with the PI. Does anyone know an alternative way I can make use of these ports? Here's a couple of images of the case and the cable for the USB
      https://imgur.com/a/xDmkU
        Hey !
        You can find on aliexpress some usb plugs that have a panel mount
        • Anonpebbles
          Hey thanks for your help yet again. I have found this and was wondering if this oculd be used? I think I would need to find a 9 pin one though..
