    X Arcade Tankstick Issue
    GamePad/GPIO/USB encoder
    arcade tankstick issue
    • samash76082
      samash76082 last edited by
      I posted this in a previous SOLVED thread, but figured I should probably set this up in it's own thread. I have the tankstick. I've confirmed that the config file has the xarcade set to 1, so it should be enabled. The red light is on. I've got the trackball connected with the usb, and I have the serial output on the other end connected with a serial to USB that was shipped with the unit. I've rebooted, and it still does not recognize the tank stick. I try to configure controllers using a separate controller, and it only finds my separate controller - not the tank stick. What am I doing wrong? I'm on a pi 3.
        Substring @samash76082 last edited by
        @samash76082 check the previous topic 😉
          move topic
