    Recalbox with illuminated Start/Stop Button
    Your recalbox
    recalbox illuminated startstop button
    • hanker
      hanker last edited by
      Hello from Germany!
      Inspired by @Colonel69 's design, I created a little Recalbox based on a oneninedesign case myself.
      Please note that I cannot recommend this build. I had to remove some GPIO pins (and even had to cut into the black plastics that is holding the pins o_O).
      Otherwise, the case looks great and I only hope that my soldering skills were good enough that the resistor (LED) and cables will stick to the switch (which is momentary, btw).
      Thanks for the great software!
      René
      • zico92
        zico92 last edited by
        Great project!!
        What is the reference for the button??
        • hanker
          hanker last edited by hanker
          http://www.ebay.de/itm/282268387843 (Germany only)
          12 mm momentary switch with integrated LED (blue), 3,3 V 15 mA, I myself used a 62 Ohm resistor for less brightness.
          • Colonel-v4
            Colonel-v4 last edited by
            Good job @hanker ! 😉
            I had hesitated with this type of button but I didn't see where to place it in the case ! XD
