    Solved Just to confirm, custom themes not supported in 4.0 ?
    Themes & Interface
    confirm themes supported 4.0
    • maximus37
      maximus37 last edited by
      My understanding is custom themes will only be supported in 4.1? If I copy a new them to the .emulationstation/themes directory, it would fail?
      • lackyluuk
        @maximus37 no, if it is customized for recalbox then it works. In 4.1 just the procedure to download and add themes is much more easier..as far as I know 🙂
        maximus37 1 Reply Last reply Reply Quote 0
        • maximus37
          maximus37 @lackyluuk last edited by
          @lackyluuk oh, ok, thanks! I will try again. I tried yesterday evening and none of the themes worked properly, I was getting a blank white screen, even with SIMPLELIGHT theme.
          • lackyluuk
            @maximus37 you can find all official themes here: https://github.com/recalbox/recalbox-themes
