    [Issue #216]
    [issue 216]
    3370
      Hello sorry for my english, iam french Bonjour sur le forum français, des tests avec ce genre de script sont en cours pour les modèles suivants :
      Github issue : https://github.com/digitalLumberjack/recalbox-os/issues/216
      Would it be possible to include the RemotePi scripts for people who have it ? All details here : http://www.msldigital.com/pages/support-for-remotepi-board-plus-2015
      Make a backup SDcard beforce testing this : put this script into /recalbox/scripts/ called it : irswitch.sh
      #!/bin/bash
      # this is the GPIO pin receiving the shut-down signal
      GPIOpin1=14
      echo "$GPIOpin1" > /sys/class/gpio/export
      echo "in" > /sys/class/gpio/gpio$GPIOpin1/direction
      while true; do
        sleep 1
        power=$(cat /sys/class/gpio/gpio$GPIOpin1/value)
        if [ $power != 0 ]; then
          echo "out" > /sys/class/gpio/gpio$GPIOpin1/direction
          echo "1" > /sys/class/gpio/gpio$GPIOpin1/value
          sleep 3
          poweroff
        fi
      done
      Make a deamon service : Put this script into /etc/init.d/ called it : S92switch
      #!/bin/bash
      ### BEGIN INIT INFO
      # Provides: irswitch.sh
      # Required-Start: $network $local_fs $remote_fs
      # Required-Stop: $network $local_fs $remote_fs
      # Default-Start: 2 3 4 5
      # Default-Stop: 0 1 6
      # Short-Description: switch init script.
      # Description: Starts and stops SwitchDaemon service.
      ### END INIT INFO
      #VAR
      RUN="/recalbox/scripts/irswitch.sh"
      BTD_PID=$(ps -eo pid,command | grep "/bin/bash $RUN" | grep -v grep | awk '{print $1}')
      serviceStatus() {
         if [ ! -z "$BTD_PID" ]; then
            echo -e '33[0mservice irswitch.sh ['$BTD_PID'] [33[33;32m OK 33[0m]'
         else
            echo -e '33[0mservice irswitch.sh [33[33;31m KO 33[0m]'
         fi
      # Carry out specific functions when asked to by the system
      case "$1" in
         start)
            echo "Starting script $RUN ..."
            if [ -z "$BTD_PID" ]; then
               nice -n 19 $RUN&
               if [ $? -eq 0 ]; then
                  echo -e "33[0mscript $RUN [33[33;32m STARTED 33[0m]"
               fi
            else
               echo "script $RUN already started ['$BTD_PID']!"
            fi
            #serviceStatus
         stop)
            echo "Stopping script $RUN ..."
               kill $BTD_PID
                  echo -e "33[0mscript $RUN [33[33;31m STOPPED 33[0m]"
               fi
            fi
            #serviceStatus
         status)
            serviceStatus
            echo "Usage: /etc/init.d/S92switch {start | stop | status}"
            exit 1
      esac
      exit 0
      make :
      chmod +x /recalbox/scripts/irswitch.sh
      chmod +x /etc/init.d/S92switch
      reboot
      Testing command line :
      /etc/init.d/S92swich start
      /etc/init.d/S92swich stop
      /etc/init.d/S92swich status
      • patriccote
        patriccote last edited by
        Hi, Been using this script on 3.3.0b17 flawlessly but it doesn't seem to work on 4.0.0 (remotePi flashes red like no shutdown script present).  Can someone confirm me if it is still valid ? Thanks ! patriccote
          Hello sorry for my english but in 4.0.0 b2 , dev add Power management boards https://github.com/recalbox/recalbox-buildroot/pull/205
          Add external switch support, by external switch configuration I mean : ATXRaspi (http://lowpowerlab.com/atxraspi/) Mausberry Circuits (http://mausberry-circuits.myshopify.com) RemotePi Board 2013 (http://www.msldigital.com) RemotePi Board 2015 (http://www.msldigital.com)
          try it.
          • patriccote
            Bonjour Acris, continuons en français alors, ce sera plus simple ! (je suis un cousin du Québec=) Je vais essayer cette semaine d'installer 4.0.0 b2 (je suis sous 4.0.0 b1 en ce moment) et de tester la procédure "Power management boards" ici : https://github.com/recalbox/recalbox-buildroot/pull/205 A guise de référence, j'ai un "RemotePi Board for Pi 2 and B+" (http://www.msldigital.com/collections/all-products/products/remotepi-board-plus-2015) Merci ! patriccote
              Super merci pour ton feedback 😄
              • patriccote
                Bonjour/Hi Acris, (English version below) 100% fonctionnel pour mon "RemotePi Board for Pi 2 and B+", après avoir activé le tout dans /recalbox/share/system/recalbox.conf ! NOTE : comme je suis passé de 4.0.0b1 à 4.0.0b2 avec l'auto-update, le fichier recalbox.conf ne contenait pas les toutes dernières variables système. J'ai donc ajouté manuellement la section suivante et j'ai activé la dernière ligne en retirant le ";" : # ------------ A - System Options ----------- # # Uncomment the system.power.switch you use ;system.power.switch=ATX_RASPI_R2_6 # http://lowpowerlab.com/atxraspi/#installation ;system.power.switch=MAUSBERRY # http://mausberry-circuits.myshopify.com/pages/setup ;system.power.switch=REMOTEPIBOARD_2003 # http://www.msldigital.com/pages/support-for-remotepi-board-2013 ;system.power.switch=REMOTEPIBOARD_2005 # http://www.msldigital.com/pages/support-for-remotepi-board-plus-2015 =-=-=-=-=-=-=-=-=-=-=-=-=-=-= 100% functionnal for my RemotePi Board for Pi 2 and B+", after activating the switch in /recalbox/share/system/recalbox.conf! NOTE : since I updated my Recalbox from 4.0.0b1 to 4.0.0b2 using the auto-update, the file recalbox.conf was not up-to-date so I added the following section and deleted the last ";" to active it : # ------------ A - System Options ----------- # # Uncomment the system.power.switch you use ;system.power.switch=ATX_RASPI_R2_6 # http://lowpowerlab.com/atxraspi/#installation ;system.power.switch=MAUSBERRY # http://mausberry-circuits.myshopify.com/pages/setup ;system.power.switch=REMOTEPIBOARD_2003 # http://www.msldigital.com/pages/support-for-remotepi-board-2013 ;system.power.switch=REMOTEPIBOARD_2005 # http://www.msldigital.com/pages/support-for-remotepi-board-plus-2015 =-=-=-=-=-=-=-=-=-=-=-=-=-=-= Merci/Thanks !!! patriccote
                  Hello oui le fichier recalbox.conf n'est pas mis à jour via l update pour ne pas perdre la configuration existante, il faut le modifier manuellement et ajouter les sections manquantes présente dans recalbox.template de mémoire.
                  • lukas2040
                    lukas2040 last edited by
                    Is there any chance to get support for the "Witty Pi"-Board (see here) with 4.0.0? Being able to shutdown using the board would be completely sufficiant for me, no need for RTC and timers. Thanks, Lukas
                      TRY to Contact LaurentMarchelli on this issue : https://github.com/recalbox/recalbox-buildroot/pull/205
                      • morpheusdev
                        morpheusdev last edited by
                        Hi Lukas, I had a look, on the version 4.0.0 beta 3, but the "wiring pi" package needed to enable Witty-pi is missing in this version. I have send a pull request for version 4.1.0, sorry for the inconvenience. Best regards, Added Witty Pi power switch support with Wiring Pi. #305 recalbox.conf<span style="font-family: Consolas, 'Liberation Mono', Menlo, Courier, monospace; font-size: 12px; white-space: pre; background-color: #eaffea;"> system.power.switch=WITTYPI</span>
                        • lukas2040
                          Hi Laurent, Thanks a lot. Did not expect so see a solution at all. You are d**n fast! Can't wait to check it out.   Best regards, Lukas
                          101.4k
