    Replacing theme background?
    replacing theme background
    • Brandon Winston
      Brandon Winston last edited by
      I like the default Recalbox theme, but I'd like to replace the background of the main menu with some custom pixel art I made.
      How can I do this?
      Anonpebbles 1 Reply Last reply Reply Quote 0
      • DAM
        DAM last edited by
        Try this:
        https://github.com/recalbox/recalbox-os/wiki/Add-emulationstation-themes-(EN)
        And:
        https://github.com/retropie/retropie-setup/wiki/Creating-Your-Own-EmulationStation-Theme
        • Anonpebbles
          Anonpebbles @Brandon Winston last edited by
          @Brandon-Winston All you would have to do is replace the background art for controllers/console with your work and set the region in the configuration file for the recalbox theme. I think you have to convert images to .SVG file type. I used a free trial of Vector magic to do this as this was the easiest way. Hope this helps
            I'd like to stress one major point : ES may blowup if you use too many high def custom backgrounds as the RAM is quite limited on Pi
