    Solved dragonrise generic encoders
    GamePad/GPIO/USB encoder
    9372
    • redcomshell
      redcomshell last edited by
      Hello,
      I recently purchased some encoders (https://smile.amazon.com/gp/product/B01FZ797OC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1) and after plugging them in and programming them they worked like they should. however once I started up a game the controller inverted left became right and up became down. If i only have one plugged in it works perfectly. I have tried to program them inverted, but they just stay that way. I also tried to go to the configuration by ssh, but I don't know where the programming would be for the controller. please help. also the joysticks are sanwa. thank you in advance.
        Substring @redcomshell last edited by
        @redcomshell mmmhhhhh now that is wierd ... On whichever emulator you said ? Could you try N64, scummvm or Moonlight to see if it's just a retroarch problem ?
        You should also try running the evtest command with both encoders plugged, and with just one plugged to see if you get the same results, then try switching from auto to sdl2 for the input method in the recalbox.conf
        • Markus
          Markus last edited by
          Hi, it seems there are many people who have the same problem, when there is this dragonrise usb in use with 2 Joysticks - except me. Is there already a solution? thx in advance.....
            Hello
            connect your encodeur and need this zip file : https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
            you need to change driver in recalbox.conf
            global.inputdriver=sdl2
            • Markus
              Markus last edited by Markus
              Hi, i uploaded the file - hope it did it right....and also changed the config file to "sdl2" but without any effects - still dont work.....Thank you
                Substring @Markus last edited by
                @Markus Can you follow https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN) so that we can have a closer look ?
                  @Substring
                  Link xxx
                  Il ma conctaté par mp
                  redcomshell 1 Reply Last reply Reply Quote 0
                  • Markus
                    @acris
                    Thanks, i was unsure to post the link public 🙂
                    • redcomshell
                      redcomshell @Markus last edited by
                      @Markus Hello did you ever get a response for your issue? i'm still having the same problem. thank you
                      • redcomshell
                        redcomshell @acris last edited by
                        @acris Hello Acris I have added a zippy file. http://www51.zippyshare.com/v/Sdlr0H2Z/file.html I tried the steps above and it didn't work. i tried both udev and sdl2. thank you in advanced.
                          Hello
                          if you have recalbox 4.0.2
                          edit /boot/cmdline.txt and add at the end of line this :
                          usbhid.quirks=0x0079:0x0006:0x040
                          like this :
                          dwc_otg.lpm_enable=0 console=tty3 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p7 rootwait fastboot noswap usbhid.quirks=0x0079:0x0006:0x040
                          save and reboot your raspberry.
                          Go to Emulationstation Menu > options gamepad.
                          Configure only player 1
                          Wal Ksys acris 2 Replies Last reply Reply Quote 0
                          • Wal Ksys
                            Wal Ksys @acris last edited by
                            @acris Hello! Did that work? I'm having the same problem now that I'm setting up my own arcade. Thank you very much!
                              Hello @Wal-Ksys
                              Yes it works but you need to find idvendor and idproduct must be different
                              Wal Ksys 2 Replies Last reply Reply Quote 0
                              • Wal Ksys
                                @acris How can I get them? I'm pretty new at this. Recalbox recognizes them as DragonRise. Thank you!
                                • Wal Ksys
                                  @acris Hello,
                                  I uploaded a file with the result of the recalbox-support.sh comman zippyshare . Does it help? thank you very much!
                                    acris @acris last edited by acris
                                    @Wal-Ksys
                                    same instructions configure only Player 1
                                    @acris said in dragonrise generic encoders:
                                    Hello
                                    https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
                                    like this :
                                    Wal Ksys 1 Reply Last reply Reply Quote 0
                                    • Wal Ksys
                                      Wal Ksys @acris last edited by Wal Ksys
                                      @acris Hello! First of all, thanks for the help, Already solved!! thank you very much!!! In the end, it was a human error. To better order the cables inside the Arcade, I did not notice and one of the levers was turned upside down !!
