    Keyboard neu mappen - iPac
    Controller/GPIO/USB
    keyboard neu mappen ipac
    3288
    • Kai-Christoph
      Kai-Christoph last edited by
      Hallo,
      ich habe mir ein Bartop gebaut. Verbaut habe ich 2 Sanwa Joysticks und jeweils 6 Buttons, sowie weitere 4 Sonderbuttons für Spielstart, Coins, etc.
      Die Knöpfe hängen an einem Ultimarc i-PAC Keyboard Encoder.
      Nun meine Frage: In welcher Datei kann ich das Keyboard ummappen?
      lg
      KC
        Hi,
        Sorry for not replying in german, but i'm the only one who ca' answer you.
        The ipac is a keyboard encoder. Therefore please read the english wiki for keyboard encoders, with a few steps the ipac should work 🙂
        Kai-Christoph 1 Reply Last reply Reply Quote 0
        • Kai-Christoph
          Kai-Christoph @Substring last edited by
          @Substring The i-PAC works in general, isn't it possible to remap the keyboard?
          I read the article in the wiki, but it only says to create an empty file withe the name of the i-PAC-Device in /recalbox/share_init/system/configs/xarcade2jstick/
          That does only works for some Buttons, but not for all.
            Substring @Kai-Christoph last edited by
            @Kai-Christoph only 9 buttons can be mapped. I have listed which key is mapped to which button, up to you to wire according to the table
            • Kai-Christoph
              @Substring
              In the Wiki I see 26 mappings for Player 1 and 2?
              https://github.com/recalbox/recalbox-os/wiki/keyboard-encoder-configuration-(EN))#v400-beta4
              Or am I wrong?
                Substring @Kai-Christoph last edited by Substring
                @Kai-Christoph Just consider v4.0.0-beta4, and yes, 26 mappings. Because we run a pad emulator on top of the keyboard encoders, and so far there are only 13 "inputs" per player
                • Kai-Christoph
                  @Substring I run the Beta, sorry not to mention that. 13 is more than enough per Player. 😉
                    @Kai-Christoph consider upgrading to the stable version 🙂
                    And try the tutorial, so you can tell me if you have problems going through it 🙂
