    Problem with Moonlight ''init'' command
    Emulator Arcade/PC/Console
    moonlight init
    • tocco93
      tocco93 last edited by tocco93
      Hi i have a problem with the setup of moonlight.
      i have follow the guide on the home page of recalbox . exit with F4,press alt+F2, pair with ''moonlight pair'' and after i pair my pi2 with pc and insert ''moonlight init'' it give me that the command in invalid.
      my recalbox is the 4.0 final ,moonlight embebbed 2.2.2 and NVIDIA GeForce GTX 1060 6GB, GFE 3.1.2.31 (protocol version 7).
      exp:
      moonlight init
      Moonlight Embedded 2.2.2 (EMBEDDED;CEC;PI)
      Searching for server...
      Connect to 192.168.1.116...
      init is not a valid action
        Substring @tocco93 last edited by
        @tocco93 please carefully read the wiki ... typing moonlight init and ./Moonlight.sh init is definitely not the same. What you type is crashing because you are calling the moonlight binary instead of caling the script that handles the init option
        tocco93 1 Reply Last reply Reply Quote 0
        • tocco93
          tocco93 @Substring last edited by
          @Substring thanks you!!!
          it work but now it tell me:
          ./Moonlight.sh init
          Fetching games from ...
          Scraping games ...
          cat: can't open '/recalbox/share/system/configs/moonlight/gamelist.txt': No such file or directory
            @tocco93 I guess you also failed the pairing, using the binary and not the script
