    GBA saves Corrupt?
    Emulator Arcade/PC/Console
    saves corrupt
    • RetroWilly
      RetroWilly last edited by
      Hello all,
      I'm having a weird problem with the GBA Emulation. Once in a while all my saved games are gone. When i check the folders the files are still there though.
      For example: I played Golden Sun for a while, and saved the game a couple of times. When i save on another game, the saved games i had from other games all disappear, or corrupt. Can it be that i don't have the right biosfile, or is it another problem. I tried switching emulators, and i keep getting the same result.
      Thanks in advance for the effort to reply 🙂
      Hello :)
        paradadf Staff last edited by
        You should try to find the cause of corruption. Bad PSU? Bad SD Card?
        • RetroWilly
          Thanks for replying,
          Both points you are directing to are good. New Samsung EVO card, and the PSU is also fine. Had the problem also on another card, before upgrading to this one. And i started with a clean install.
          Hello :)
