    Set specific resolution for single game
    specific single
    2321
    • 0zzy
      0zzy last edited by
      Hi all, is it possibile to set a specific resolutions only for a few single roms?
        Depends on what resolution you mean. Could you give some more details ?
        0zzy 1 Reply Last reply Reply Quote 0
        • 0zzy
          0zzy @Substring last edited by
          @Substring hi, i'm wrong, i mean aspect ratio.
          if i run arkanoid on mame it's better to set AR to 1:1 on retroarch.
            the aspect ration is automatic on mame or fba, or any emulator. There are hardly any game/emulator running a 1:1, which means a square picture
              voljega Banned @Substring last edited by voljega
              @Substring not sure if it has been corrected but vertical games (3/4) on mame used to be displayed incorrectly as 4/3 and stretched from 3/4 to 4/3
              @0zzy I usually use those games with the fba_libretro emulator wich displays them correctly, however you will have to find the correct romset
                Substring @voljega last edited by
                @voljega it's solved since beta4 or 5
