    How to emulate recalboxOS v4.0 using qemu?
    emulate v4.0 qemu
    5865
    • Txiki Diaspora
      Txiki Diaspora last edited by
      Hi.
      I'm trying to launch recalboxOS v4.0.0 using qemu-system-arm and it seems I'm doing something wrong.
      After install qemu in Fedora 25:
      sudo dnf install qemu
      I downloaded recalbox v4 from here
      Then, I try to create a valid iso using:
      fallocate -l 1G recalbox_image.img                                     # Create img file
      mkfs.msdos recalbox_image.img                                        # Set fat32 format
      mkdir recalbox        # Create temporal folder
      sudo mount -o loop recalbox_image.img ./recalbox    # Mount img in folder
      sudo unzip recalboxOS-4.0.0.zip -d recalbox                  # Unzip recalbox 4 in img
      genisoimage -o recalbox.iso recalbox                                # Create iso
      After creating iso, I try to launch it using:
      qemu-system-arm -machine raspi2 -hda recalbox_image.img -m 1024 # Launch nothing
      It is probably a problem with missing kernel or something. I tried to download raspbian kernels to use them from:
      git clone https://github.com/dhruvvyas90/qemu-rpi-kernel
      But nothing:
      qemu-system-arm -machine raspi2 -hda recalbox_image.img -m 1024 -kernel qemu-rpi-kernel/kernel-qemu-4.4.13-jessie -append "root=/dev/sda2" # Nothing happend
      and using:
      qemu-system-arm -M versatilepb -cpu arm1176 -hda recalbox_image.img -kernel qemu-rpi-kernel/kernel-qemu-4.4.13-jessie -m 1024 -append "root=/dev/sda2"
      neither (any version). Someone know what kernel or configuration I must to use?
        As far as i remember qemu id dreadly slow and hardly emulates a pi0 + iy can't handle the hdmi display, so i don't think you'll get anything with it
        • 0zzy
          0zzy last edited by
          Hi, i have seen rasbpbian is emulated under windows here https://sourceforge.net/projects/rpiqemuwindows/
          I would like to virtualize recalbox for testing purpose, someone have tried?
            voljega Banned @0zzy last edited by
            @0zzy recalbox is not a raspian. Besides emulators in emulator... Not usable at all
              Substring @0zzy last edited by
              @0zzy haven't tried qemu for ages, but last time i tried it had horrible performance emulating a pi1 ... And I'm not sure it can run real video output. But you should go ahead and try, we dev don't have much time to test such things
              • 0zzy
                0zzy last edited by 0zzy
                hi all!
                i was looking to emulate recalbox only to test roms quickly, because my raspy is far from my desktop, and because i'm a vcp, i like to virtualize all 😄
                  @0zzy well, keep trying, i'd be curious to see how it works afterall 🙂
