    Install USB network card (for upgrade Moonlight quality)
    usb network card upgrade moonlight
    2844
    • MicroDark
      MicroDark last edited by MicroDark
      Hi all,
      I try to install a USB ethernet card (1 gigabit) for use the max rate of USB2 port (so upgrade the network connexion from 10 MB/s to 22MB/s) for a better Moonlight support.
      I connect the device, turn on the Recalbox... and nothing on the thernet leds...
      So I suppose I have to install the driver (and I have it), but how can I do that ?
      Thanks in advance for help.
        a usb card won't go faster than the embedded ethernet port as it's still some slow USB2 behind
        • MicroDark
          22 MBPS is faster than 10 MBPS
          • MicroDark
            So, nobody have a solution ? 😞
              Substring @MicroDark last edited by
              @MicroDark what is wrong with the embedded NIC ?
              • MicroDark
                I'm limited to 100 Mbps for Moonlight streaming when I can obtain 220 Mbps with a USB gigabit ethernet.
                  @MicroDark i've almost never experienced any trouble with moonlight in 720p with the embedded ehternet. Anyway, it's on the same sluggish USB2 bus inside the pi
                  • MicroDark
                    So, nobody can help me ? 😞
                    101.4k
