    Shaders set via recalbox config are not applied for FBA
    Emulator Arcade/PC/Console
    shaders recalbox config are applied
    3793
    • Yoakin
      Yoakin last edited by
      Hey everyone.
      I have the following problem:
      I set up some default shaders for different systems via the recalbox config. For example for Gameboy with gb.shaders=/recalbox/share_init/shaders/dot.glslp. And so on.
      Works perfectly for all systems except FBA. I've set the CRT Caligari shader for FBA with the following command:
      fba_libretro.shaders=/recalbox/share_init/shaders/crt-caligari_gamma_125.glslp
      When I start a game with FBA, the shaders are selected in the RetroArch menu but not applied. For every game I have to got in the RetroArch menu and select "Apply shader settings" manually.
      How can I make FBA apply autoamtically?
      PS: It works for NeoGeo btw (which also uses FBA) with neogeo.shaders command.
        Hi.
        Without your recalbox version, I can't help you much
        • Yoakin
          The version is 4.0.0-build-121.
            Substring @Yoakin last edited by
            @Yoakin that may be caused by sthg we solved in 4.1 (fba_libretro was also named fbalibretro in the code, therefore some unexpected behaviours). 2 possibilities:
            • set the global shader yourself, it sgould fall back on fba
            • try fbalibretro.shaders=blabla (remove the _ from fba_libretro)
            • Yoakin
              Thanks a lot! Using "fbalibretro.shaders" instead of "fba_libretro.shaders" did the trick!
                @Yoakin you will have to change it back to fba_libretro in 4.1 😉
