    Controller doesn't work when using own config
    Emulator Arcade/PC/Console
    doesnt own config
    3201
    • Yoakin
      Yoakin last edited by
      Hi.
      I'm sorry if that question has already been answered before, but I couldn't find anything.
      I am having the following problem:
      I want to save for each system my own shader settings. So I select the shader that I want to use, go to the Retroarch menu and select "Save new config".
      In the recalbox config I now assign this new cfg file to the emulator via this command (for SNES for example): snes.configfile=/recalbox/share/system/.config/retroarch/config/snes9x_next.cfg
      When I start a SNES game now, the config is loaded with the correct shader settings but my controls won't work anymore. No inputs are possible.
      When I use the retroarchcustom.cfg everything works fine. What am I doing wrong?
      • kiri-mandarine
        kiri-mandarine last edited by
        almost same thing here, when i load (manualy) any custom config. i lost my "hotkey" (and some lines in menu, a.e. "resume" line) i cant get back to game.
        don't know if other keys are impacted too... cant play ^^
        kiri-mandarine 1 Reply Last reply Reply Quote 0
        • kiri-mandarine
          kiri-mandarine @kiri-mandarine last edited by
          @kiri-mandarine said in Controller doesn't work when using own config:
          precision : same behavior with all emulators
            Substring @kiri-mandarine last edited by
            What did you add in your cfg file ? There is an easier way to set shaders
            • kiri-mandarine
              kiri-mandarine @Substring last edited by
              @Substring said in Controller doesn't work when using own config:
              In my case :
              • shader and/or overlay, and/or just a key remaping. i cant load a cfgfile from in game menu.
              even if I save the default config (menu/save new config) without changing anything. when I load manualy this config file, I lost the "hotkey" AND the "resume" option on the menu, so can t go back to game.
              Yoakin seems to have the same pb.
                Have you both read https://github.com/recalbox/recalbox-os/wiki/Shaders-configuration-(EN) ?
