    Missing gamelist.xml
    recalbox4.0 romset gamelist.xml
    • Everett999
      Everett999 last edited by
      Hi,
      First, can someone explain what the gamelist.xml file does and why it is in every rom folder?
      It seems that in the process of adding and deleting roms a few of my folders are now missing the gamelist.xml file. I probably deleted it by accident.
      What is the proper way to add and edit it if needed?
      Thanks!
      • ian57
        ian57 Staff last edited by
        In EmulationStation interface, juste Update the list game in the Games menu.
        • Anonpebbles
          Anonpebbles last edited by
          You only need it if you're scraping games. I would suggest using this to scrape your games from desktop and then transferring the gamelist.xml and stuff over.
