    Solved Problem in Odyssey² / FDS / PC Engine CD
    Emulator Arcade/PC/Console
    odyssey² fds engine
    • azvarel
      azvarel last edited by
      Guys,
      I can not run the games on these consoles.
      Odyssey already .bin and .zip files and it just does not work
      Famicom Diski System already .fds and .zip files and simply does not work
      PC Engine CD already .cue with .iso, but does not work
      I need help.
      Zodian Theme | #SNESProject
      • azvarel
        I using recalboxOS-4.0.0-beta6
          paradadf Staff last edited by
          Do you have the bios?
          https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN)
          azvarel 1 Reply Last reply Reply Quote 0
          • azvarel
            azvarel @paradadf last edited by
            @paradadf thanks! Case solved.
