    XBMC back into Emulationstation
    xbmc
    12
    25
    10088
      Hello the fix will be in the next release, the 3.3.0. The bêta release is imminent.
      • ivwshane
        ivwshane last edited by
        Sweet! Does this also fix the issue where a CEC compatible tv is turned off when exiting kodi?
        • digitaLumberjack
          You can test the beta ad tell us @ivwshane 🙂
          • joinski
            joinski last edited by
            The Problem with kodi (pressing exit to leave kodi turns off tv) can easily be fixed by editing the cec-settings in kodi. You have to go to System -> Settings -> System -> Input Devices -> Peripherals -> CEC adapter and then change the setting for « Devices to power off when stopping Kodi » to none.
            • ivwshane
              @joinski   Oh sh!t! I never even knew about that setting! Thanks!
              100.6k
