    Black Screen with Moonlight
    Emulator Arcade/PC/Console
    moonlight
    3762
    • rob
      rob last edited by
      Hi guys, thanks for this great project. Almost everything works out of the box. Really cool!!
      Today i have upgraded my system to Version 4.00 beta 5 and i'm trying to get moonlight to work.
      Pairing and scraping works without any problem. When i start steam with moonlight i get a black screen on the tv. The Computer is switching to big picture mode and i can control the pc with my recalbox controler. Sound works also over the tv, just the tv remains black.
      Any ideas?
      Regards, rob
        Hey @rob !
        You're running GFE 3.0.7right ? so 2 choices remain :
        • either switch to the unstable branch
        • either wait for the next release
        rob 1 Reply Last reply Reply Quote 0
        • rob
          rob @Substring last edited by rob
          Thanks for the quick reply. I will try another version later.
          Cheers
          • rob
            rob last edited by
            It works with GFE 2.2.2, thank you!!
            Now i have a little problem with my PS3 controller. The horizontal axis from the right analog stick doesn't work, only with moonlight... Vertical axis works perfect.
            I have remapped the pad in emulation station and i also tried the mapping in moonlight with ./moonlight.sh map. The stick works in the mapping tool and also in other emulators like n64...
              mmmhhh could you paste the content of ~/configs/moonlight/mappingP1.conf ?
              • rob
                rob last edited by rob
                # Device name = PLAYSTATION(R)3 Controller
                # SDL2 GUID   = 060000004c0500006802000000010000
                # Event path  = /dev/input/event2
                btn_west = 300
                btn_tl2 = 296
                btn_dpad_left = 295
                reverse_dpad_y = false
                reverse_dpad_x = false
                btn_dpad_down = 294
                btn_dpad_up = 292
                abs_ry = 3
                abs_deadzone = 4
                btn_south = 301
                btn_start = 291
                btn_dpad_right = 293
                reverse_ry = true
                reverse_rx = false
                btn_mode = 304
                abs_x = 0
                abs_y = 1
                btn_tr2 = 297
                reverse_x = false
                reverse_y = true
                btn_thumbl = 289
                btn_east = 302
                btn_select = 288
                btn_tr = 299
                btn_north = 303
                btn_tl = 298
                btn_thumbr = 290
                and if needed the es_input.cfg
                	<inputConfig type="joystick" deviceName="PLAYSTATION(R)3 Controller" deviceGUID="060000004c0500006802000000010000">
                		<input name="a" type="button" id="13" value="1" code="301" />
                		<input name="b" type="button" id="14" value="1" code="302" />
                		<input name="down" type="button" id="6" value="1" code="294" />
                		<input name="hotkey" type="button" id="16" value="1" code="304" />
                		<input name="joystick1left" type="axis" id="0" value="-1" code="0" />
                		<input name="joystick1up" type="axis" id="1" value="-1" code="1" />
                		<input name="joystick2left" type="axis" id="2" value="-1" code="2" />
                		<input name="joystick2up" type="axis" id="3" value="-1" code="3" />
                		<input name="l2" type="button" id="8" value="1" code="296" />
                		<input name="l3" type="button" id="1" value="1" code="289" />
                		<input name="left" type="button" id="7" value="1" code="295" />
                		<input name="pagedown" type="button" id="11" value="1" code="299" />
                		<input name="pageup" type="button" id="10" value="1" code="298" />
                		<input name="r2" type="button" id="9" value="1" code="297" />
                		<input name="r3" type="button" id="2" value="1" code="290" />
                		<input name="right" type="button" id="5" value="1" code="293" />
                		<input name="select" type="button" id="0" value="1" code="288" />
                		<input name="start" type="button" id="3" value="1" code="291" />
                		<input name="up" type="button" id="4" value="1" code="292" />
                		<input name="x" type="button" id="12" value="1" code="300" />
                		<input name="y" type="button" id="15" value="1" code="303" />
                	</inputConfig>
                  yeah, a typo that i solved (cuz i'm the one responsible for it) a few weeks ago https://github.com/recalbox/recalbox-configgen/commit/0e88ab998ad2dacf86e3138e2c3c0522fc474394
                  once again : either switch to the unstable, either wait for the next release 😕
                  in fact, you can even solve it yourself if you have a few basc skills in linux
                  • rob
                    @subs
                    Thanks again. I fixed it with a new mappingP1.conf
                    this works perfect...
                    abs_x = 0
                    abs_y = 1
                    abs_z = 50
                    abs_rx = 2
                    abs_ry = 3
                    abs_rz = 51
                    abs_deadzone = 4
                    abs_dpad_x = 0
                    abs_dpad_y = 0
                    reverse_x = false
                    reverse_y = true
                    reverse_rx = false
                    reverse_ry = true
                    btn_west = 303
                    btn_south = 302
                    btn_north = 300
                    btn_east = 301
                    btn_select = 288
                    btn_start = 291
                    btn_mode = 304
                    btn_thumbl = 289
                    btn_thumbr = 290
                    btn_tl = 298
                    btn_tr = 299
                    btn_tl2 = 296
                    btn_tr2 = 297
                    btn_dpad_up = 292
                    btn_dpad_down = 294
                    btn_dpad_left = 295
                      Substring @rob last edited by
                      @rob yeah, can be done that way. But if you ever bring in another pad, it can be messed up. But you understood how t fix it anyway for ypur needs 🙂
