    N64: SNES-Controller does not cover all buttons?
    Emulator Arcade/PC/Console
    snes-controller does cover buttons
    • RK.aus.S
      RK.aus.S last edited by
      Hello
      I'm new with Recalbox and do use it with SNES controller(s). Now I note that sometimes I miss some buttons to play a game:
      For example: I want to play the N64 game "Zelda - Ocarina of Time" with the SNES controller. Allmost all works perfectly but in one case - if I want to talk to Links fairy "Navi" - I cannot not find the appropriate button on my SNES controller? I tried arround a long time and noted that if I connect an additional USB keyboard, then I can press the key "I" to talk to "Navi".
      Is there a way to fit the controller button mapping so that the whole game is playable with the SNES controller only?
      Regards,
      Roman
      • Nachtgarm
        Nachtgarm last edited by
        Hi @RK-aus-S
        I don't think so...
        We're talking 10 Buttons, an Analog Stick and a D-Pad (N64) against 8 Buttons and a D-Pad (SNES).
        Talking to Navi is the yellow UP Button on the N64 Pad. Maybe this helps http://strategywiki.org/wiki/The_Legend_of_Zelda:_Ocarina_of_Time/Controls
        Consider using a PS3 Pad or something alike.
        https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)#pad-controller
        • RK.aus.S
          RK.aus.S last edited by RK.aus.S
          Hi Nachtgarm
          Thank you very much!
          I've connected my wired Xbox360 controller, and now I'm able to talk/listen to "Navi"! (Yellow Y Button 🙂
          The only thing I cannot find at the moment is to select the Save Slots with this controller? Even I press Hotkey + Up/Down within the N64 game "Zelda", nothing happens. Selecting a Save Slot within a MAME game works!
          Is it possible that selecting Save Slots is depending which emulator I run?
          Regards,
          Roman
