    Solved n64 blank screen returns to ES log says ...launch terminated with nonzero exit code 2560!
    Emulator Arcade/PC/Console
    blank returns log says launch
    • mchack23
      mchack23 last edited by
      well title says it all I guess.
      I'm on recalbox 4.0 beta 5 and it's the same with any rom I tried and any emulator/core. I configured all buttons of my ps3 controller (connected via bt stick) I tried different DMT and CEA settings but it doesn't change the fact that it's always launch terminated with exit code 2560.
      Anyone know what that exit code means?
      snip from the .emulationstation/es_log.txt:
      lvl2: Added known joystick PLAYSTATION(R)3 Controller (instance ID: 0, device index: 0)
      lvl2: SDL AUDIO Initialized
      lvl2: Attempting to launch game...
      lvl2: Shutting down SDL AUDIO
      lvl2: Available and configurated : PLAYSTATION(R)3 Controller
      lvl2: No config for player 0
      lvl2: So i set PLAYSTATION(R)3 Controller for player 0
      lvl2: No config for player 1
      lvl2: No config for player 2
      lvl2: No config for player 3
      lvl2: No config for player 4
      lvl2: Configure emulators command : -p1index 0 -p1guid 060000004c0500006802000000010000 -p1name "PLAYSTATION(R)3 Controller" -p1devicepath /dev/input/event3
      lvl2: Controllers config : -p1index 0 -p1guid 060000004c0500006802000000010000 -p1name "PLAYSTATION(R)3 Controller" -p1devicepath /dev/input/event3
      lvl2: python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 060000004c0500006802000000010000 -p1name "PLAYSTATION(R)3 Controller" -p1devicepath /dev/input/event3 -system n64 -rom /recalbox/share/roms/n64/Mario\ Kart\ 64\ (USA).zip -emulator default -core default
      lvl1: ...launch terminated with nonzero exit code 2560!
      lvl2: Creating surface...
      lvl2: Created window successfully.
      lvl2: EmulationStation cleanly shutting down.
        paradadf Staff @mchack23 last edited by
        @mchack23 read the readme in every rom folder. n64 games can't be zipped.
        • mchack23
          well, bit embarrasing but thank you very much 🙂 works fine now 😄
