    New wad for Doom II
    Your discoveries
    wad doom
    8101
    • Jesús BL
      Jesús BL last edited by Jesús BL
      Doom 2 modder spends 300 hours making a three-hour level.
      Doom II new modder
      By the way, In which directory can I add more wad files for Doom?
      Edit 4 nov'16: The directory is prboom
      Trucos y recetas para raspberry pi:
      http://malagaoriginal.blogspot.com.es/search/label/raspberry pi
      DJ PC Board Substring 2 Replies Last reply Reply Quote 0
      • DJ PC Board
        DJ PC Board @Jesús BL last edited by
        @Jesús-BL Lo has probado en la Recalbox?
        Este ya si que tiene que la bomba: http://www.moddb.com/mods/brutal-doom-64
        Do you try it on Recalbox?
        This will be a bomb: http://www.moddb.com/mods/brutal-doom-64
          Substring @Jesús BL last edited by
          @Jesús-BL in the doom rom folder ! where else ???
          Jesús BL 1 Reply Last reply Reply Quote 0
          • Jesús BL
            Jesús BL @Substring last edited by Jesús BL
            @subs I found the folder, I also tought that would be doom but it's prboom.
              prboom indeed ... i can't say that's a system i often use ... So could you test this mod on recalbox ?
              • Jesús BL
                @subs I try Foursite and PrBoom wads but they don't start and after a few seconds return to lists of wads, only shareware wad runs ok!
                levendis32 1 Reply Last reply Reply Quote 0
                • levendis32
                  levendis32 Translator Banned @Jesús BL last edited by
                  @Jesús-BL Hey have played Brutal Doom on Recalbox ?
                  • levendis32
                    levendis32 Translator Banned @levendis32 last edited by
                    @levendis32 said:
                    @Jesús-BL have you played Brutal Doom on Recalbox ?
                    Can you help me get DOOM 2 on Recalbox?
                      prBoom need wad only.
                      please dont up before 24h
                      https://forum.recalbox.com/topic/7531/brutal-doom-can-recalbox-play-it
                      101.4k
