    Tron rom loads but can't insert coin nor tab for mame menu
    Emulator Arcade/PC/Console
    mame tron rom
    • thanosazlin
      thanosazlin last edited by
      i have a 0.78 rom set, and there are 2 files for tron , tron.zip and tron2.zip , all other roms work fine. for some reason when tron loads my buttons don't work at all , can't insert coin. i hit tab for mame emulator menu and nothing happens. i can hit escape and it quits and i can use my hotkey combo and it exits the emulator.
      anyone else see this or have a solution? i love tron it was one of my favs.
        paradadf Staff @thanosazlin last edited by paradadf
        @thanosazlin it is a known issue:
        https://github.com/libretro/mame2003-libretro/issues/55
        • Nachtgarm
          Nachtgarm last edited by
          Wrong category. Topic was moved
          • gkralicek2
            gkralicek2 last edited by
            Tron, Journey, Tapper and Satan's Hollow (maybe a few more) have this problem with Mame 2000 or Mame 2003 cores. The only way to get around this is to use Mame 2010 core instead which fixes the problem.
            100.6k
