    Zero Delay does not keep settings
    GamePad/GPIO/USB encoder
    bartop arcade zero-delay dragonrise
    6223
    • Bruno Fonseca
      Bruno Fonseca last edited by
      Raspberry pi 3
      Recalbox 4.0.0 beta 5
      hello friends I have a bartop 90% assembled and lack only solve this problem: I use two zero delay as controller cards, I can set the player 1 and player 2 in the main menu at the station emulation and it looks like this:
      Menu> Controller Settings>
      #0 Dragonrise INC. ... ick
      #1 Dragonrise INC. ... ick
      I can not use normally, but when I access a game control 2 (sometimes 1) gets the A and B button reversed, this happens both in recalbox as in retropie ......
      Can anyone give me a hand with this?
      • Nachtgarm
        Nachtgarm last edited by
        @subs might be the man to ask for help about this.
          Mmhhhhh ..... Are both your controllers wired the same way ? On which emulator(s) does it happen ?
          • Bruno Fonseca
            Yes the controls are the same as are in the picture below, the problem is when I finish setting the menu and access an emulator or any restart the recalbox settings change ... precisely the A and B buttons (sometimes the contole 1 keeps the settings and the second does not)
            2_1474983022172_P_20160927_102115.jpg 1_1474983022172_P_20160927_102052.jpg 0_1474983022172_P_20160927_102043.jpg
              this is why i believe there is a wiring problem ...
              • Bruno Fonseca
                No, I've set everything right as well as the wire, the problem is when I go into the emulator any and then leave and return to the main menu buttons are misconfigured.
                  Can you post zip file of this wiki
                  https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
                  • Bruno Fonseca
                    @acris its zip her: http://www.4shared.com/archive/ZH9ywvtMce/recalbox-support-2016092717491.html
                    txota69 1 Reply Last reply Reply Quote 0
                      Configuration files are rewritten at each emulator start. If you need your changes to be saved, you need to read the custom config section of the wiki
                      • txota69
                        txota69 @Bruno Fonseca last edited by
                        @Bruno-Fonseca could you fix the problem? i'm in the same way. i'n not able to keep my configurarion when i start an emulator. Thanks!!
