    Keyboard issue
    keyboard issue
    2910
    • sirus555
      sirus555 last edited by
      Hi all,
      I have one of these keyboard ;https://www.amazon.co.uk/Wireless-Keyboard-Esynic-Touchpad-Mouse/dp/B00DUUF250/ref=sr_1_3?ie=UTF8&qid=1474488696&sr=8-3&keywords=kodi+keyboard
      I am having an issue with its current map e.g. no mouse scroll or right/left click. I changed the recal config to map as en_GB but that hasn't done anything different.
      Any idea if there is a better way to map the keys?
        Can you try running evtest ?
        • sirus555
          Hi,
          I get two event:
          /dev/input/event0: SINO WEALTH USB Composite Device
          /dev/input/event1: SINO WEALTH USB Composite Device
          First one:
          Input driver version is 1.0.1
          Input device ID: bus 0x3 vendor 0x603 product 0x2 version 0x110
          Input device name: "SINO WEALTH USB Composite Device"
          Supported events:
          Event type 0 (EV_SYN)
          Event type 1 (EV_KEY)
          Event code 1 (KEY_ESC)
          Event code 2 (KEY_1)
          Event code 3 (KEY_2)
          Event code 4 (KEY_3)
          Event code 5 (KEY_4)
          Event code 6 (KEY_5)
          Event code 7 (KEY_6)
          Event code 8 (KEY_7)
          Event code 9 (KEY_8)
          Event code 10 (KEY_9)
          Event code 11 (KEY_0)
          Event code 12 (KEY_MINUS)
          Event code 13 (KEY_EQUAL)
          Event code 14 (KEY_BACKSPACE)
          Event code 15 (KEY_TAB)
          Event code 16 (KEY_Q)
          Event code 17 (KEY_W)
          Event code 18 (KEY_E)
          Event code 19 (KEY_R)
          Event code 20 (KEY_T)
          Event code 21 (KEY_Y)
          Event code 22 (KEY_U)
          Event code 23 (KEY_I)
          Event code 24 (KEY_O)
          Event code 25 (KEY_P)
          Event code 26 (KEY_LEFTBRACE)
          Event code 27 (KEY_RIGHTBRACE)
          Event code 28 (KEY_ENTER)
          Event code 29 (KEY_LEFTCTRL)
          Event code 30 (KEY_A)
          Event code 31 (KEY_S)
          Event code 32 (KEY_D)
          Event code 33 (KEY_F)
          Event code 34 (KEY_G)
          Event code 35 (KEY_H)
          Event code 36 (KEY_J)
          Event code 37 (KEY_K)
          Event code 38 (KEY_L)
          Event code 39 (KEY_SEMICOLON)
          Event code 40 (KEY_APOSTROPHE)
          Event code 41 (KEY_GRAVE)
          Event code 42 (KEY_LEFTSHIFT)
          Event code 43 (KEY_BACKSLASH)
          Event code 44 (KEY_Z)
          Event code 45 (KEY_X)
          Event code 46 (KEY_C)
          Event code 47 (KEY_V)
          Event code 48 (KEY_B)
          Event code 49 (KEY_N)
          Event code 50 (KEY_M)
          Event code 51 (KEY_COMMA)
          Event code 52 (KEY_DOT)
          Event code 53 (KEY_SLASH)
          Event code 54 (KEY_RIGHTSHIFT)
          Event code 55 (KEY_KPASTERISK)
          Event code 56 (KEY_LEFTALT)
          Event code 57 (KEY_SPACE)
          Event code 58 (KEY_CAPSLOCK)
          Event code 59 (KEY_F1)
          Event code 60 (KEY_F2)
          Event code 61 (KEY_F3)
          Event code 62 (KEY_F4)
          Event code 63 (KEY_F5)
          Event code 64 (KEY_F6)
          Event code 65 (KEY_F7)
          Event code 66 (KEY_F8)
          Event code 67 (KEY_F9)
          Event code 68 (KEY_F10)
          Event code 69 (KEY_NUMLOCK)
          Event code 70 (KEY_SCROLLLOCK)
          Event code 71 (KEY_KP7)
          Event code 72 (KEY_KP8)
          Event code 73 (KEY_KP9)
          Event code 74 (KEY_KPMINUS)
          Event code 75 (KEY_KP4)
          Event code 76 (KEY_KP5)
          Event code 77 (KEY_KP6)
          Event code 78 (KEY_KPPLUS)
          Event code 79 (KEY_KP1)
          Event code 80 (KEY_KP2)
          Event code 81 (KEY_KP3)
          Event code 82 (KEY_KP0)
          Event code 83 (KEY_KPDOT)
          Event code 85 (KEY_ZENKAKUHANKAKU)
          Event code 86 (KEY_102ND)
          Event code 87 (KEY_F11)
          Event code 88 (KEY_F12)
          Event code 89 (KEY_RO)
          Event code 90 (KEY_KATAKANA)
          Event code 91 (KEY_HIRAGANA)
          Event code 92 (KEY_HENKAN)
          Event code 93 (KEY_KATAKANAHIRAGANA)
          Event code 94 (KEY_MUHENKAN)
          Event code 95 (KEY_KPJPCOMMA)
          Event code 96 (KEY_KPENTER)
          Event code 97 (KEY_RIGHTCTRL)
          Event code 98 (KEY_KPSLASH)
          Event code 99 (KEY_SYSRQ)
          Event code 100 (KEY_RIGHTALT)
          Event code 102 (KEY_HOME)
          Event code 103 (KEY_UP)
          Event code 104 (KEY_PAGEUP)
          Event code 105 (KEY_LEFT)
          Event code 106 (KEY_RIGHT)
          Event code 107 (KEY_END)
          Event code 108 (KEY_DOWN)
          Event code 109 (KEY_PAGEDOWN)
          Event code 110 (KEY_INSERT)
          Event code 111 (KEY_DELETE)
          Event code 113 (KEY_MUTE)
          Event code 114 (KEY_VOLUMEDOWN)
          Event code 115 (KEY_VOLUMEUP)
          Event code 116 (KEY_POWER)
          Event code 117 (KEY_KPEQUAL)
          Event code 119 (KEY_PAUSE)
          Event code 121 (KEY_KPCOMMA)
          Event code 122 (KEY_HANGUEL)
          Event code 123 (KEY_HANJA)
          Event code 124 (KEY_YEN)
          Event code 125 (KEY_LEFTMETA)
          Event code 126 (KEY_RIGHTMETA)
          Event code 127 (KEY_COMPOSE)
          Event code 128 (KEY_STOP)
          Event code 129 (KEY_AGAIN)
          Event code 130 (KEY_PROPS)
          Event code 131 (KEY_UNDO)
          Event code 132 (KEY_FRONT)
          Event code 133 (KEY_COPY)
          Event code 134 (KEY_OPEN)
          Event code 135 (KEY_PASTE)
          Event code 136 (KEY_FIND)
          Event code 137 (KEY_CUT)
          Event code 138 (KEY_HELP)
          Event code 140 (KEY_CALC)
          Event code 142 (KEY_SLEEP)
          Event code 150 (KEY_WWW)
          Event code 152 (KEY_SCREENLOCK)
          Event code 158 (KEY_BACK)
          Event code 159 (KEY_FORWARD)
          Event code 161 (KEY_EJECTCD)
          Event code 163 (KEY_NEXTSONG)
          Event code 164 (KEY_PLAYPAUSE)
          Event code 165 (KEY_PREVIOUSSONG)
          Event code 166 (KEY_STOPCD)
          Event code 173 (KEY_REFRESH)
          Event code 176 (KEY_EDIT)
          Event code 177 (KEY_SCROLLUP)
          Event code 178 (KEY_SCROLLDOWN)
          Event code 179 (KEY_KPLEFTPAREN)
          Event code 180 (KEY_KPRIGHTPAREN)
          Event code 183 (KEY_F13)
          Event code 184 (KEY_F14)
          Event code 185 (KEY_F15)
          Event code 186 (KEY_F16)
          Event code 187 (KEY_F17)
          Event code 188 (KEY_F18)
          Event code 189 (KEY_F19)
          Event code 190 (KEY_F20)
          Event code 191 (KEY_F21)
          Event code 192 (KEY_F22)
          Event code 193 (KEY_F23)
          Event code 194 (KEY_F24)
          Event code 240 (KEY_UNKNOWN)
          Event type 4 (EV_MSC)
          Event code 4 (MSC_SCAN)
          Event type 17 (EV_LED)
          Event code 0 (LED_NUML) state 0
          Event code 1 (LED_CAPSL) state 0
          Event code 2 (LED_SCROLLL) state 0
          Key repeat handling:
          Repeat type 20 (EV_REP)
          Repeat code 0 (REP_DELAY)
          Value 250
          Repeat code 1 (REP_PERIOD)
          Value 33
          Properties:
          Testing ... (interrupt to exit)
          And second:
          Supported events:
          Event code 139 (KEY_MENU)
          Event code 143 (KEY_WAKEUP)
          Event code 144 (KEY_FILE)
          Event code 155 (KEY_MAIL)
          Event code 156 (KEY_BOOKMARKS)
          Event code 167 (KEY_RECORD)
          Event code 168 (KEY_REWIND)
          Event code 169 (KEY_PHONE)
          Event code 171 (KEY_CONFIG)
          Event code 172 (KEY_HOMEPAGE)
          Event code 174 (KEY_EXIT)
          Event code 181 (KEY_NEW)
          Event code 182 (KEY_REDO)
          Event code 206 (KEY_CLOSE)
          Event code 207 (KEY_PLAY)
          Event code 208 (KEY_FASTFORWARD)
          Event code 209 (KEY_BASSBOOST)
          Event code 210 (KEY_PRINT)
          Event code 212 (KEY_CAMERA)
          Event code 216 (KEY_CHAT)
          Event code 217 (KEY_SEARCH)
          Event code 219 (KEY_FINANCE)
          Event code 223 (KEY_CANCEL)
          Event code 224 (KEY_BRIGHTNESSDOWN)
          Event code 225 (KEY_BRIGHTNESSUP)
          Event code 228 (KEY_KBDILLUMTOGGLE)
          Event code 231 (KEY_SEND)
          Event code 232 (KEY_REPLY)
          Event code 233 (KEY_FORWARDMAIL)
          Event code 234 (KEY_SAVE)
          Event code 235 (KEY_DOCUMENTS)
          Event code 241 (KEY_VIDEO_NEXT)
          Event code 244 (KEY_BRIGHTNESS_ZERO)
          Event code 256 (BTN_0)
          Event code 272 (BTN_LEFT)
          Event code 273 (BTN_RIGHT)
          Event code 274 (BTN_MIDDLE)
          Event code 275 (BTN_SIDE)
          Event code 276 (BTN_EXTRA)
          Event code 353 (KEY_SELECT)
          Event code 354 (KEY_GOTO)
          Event code 358 (KEY_INFO)
          Event code 362 (KEY_PROGRAM)
          Event code 366 (KEY_PVR)
          Event code 370 (KEY_SUBTITLE)
          Event code 372 (KEY_ZOOM)
          Event code 374 (KEY_KEYBOARD)
          Event code 376 (KEY_PC)
          Event code 377 (KEY_TV)
          Event code 378 (KEY_TV2)
          Event code 379 (KEY_VCR)
          Event code 380 (KEY_VCR2)
          Event code 381 (KEY_SAT)
          Event code 383 (KEY_CD)
          Event code 384 (KEY_TAPE)
          Event code 386 (KEY_TUNER)
          Event code 387 (KEY_PLAYER)
          Event code 389 (KEY_DVD)
          Event code 392 (KEY_AUDIO)
          Event code 393 (KEY_VIDEO)
          Event code 396 (KEY_MEMO)
          Event code 397 (KEY_CALENDAR)
          Event code 398 (KEY_RED)
          Event code 399 (KEY_GREEN)
          Event code 400 (KEY_YELLOW)
          Event code 401 (KEY_BLUE)
          Event code 402 (KEY_CHANNELUP)
          Event code 403 (KEY_CHANNELDOWN)
          Event code 405 (KEY_LAST)
          Event code 407 (KEY_NEXT)
          Event code 408 (KEY_RESTART)
          Event code 409 (KEY_SLOW)
          Event code 410 (KEY_SHUFFLE)
          Event code 412 (KEY_PREVIOUS)
          Event code 416 (KEY_VIDEOPHONE)
          Event code 417 (KEY_GAMES)
          Event code 418 (KEY_ZOOMIN)
          Event code 419 (KEY_ZOOMOUT)
          Event code 420 (KEY_ZOOMRESET)
          Event code 421 (KEY_WORDPROCESSOR)
          Event code 422 (KEY_EDITOR)
          Event code 423 (KEY_SPREADSHEET)
          Event code 424 (KEY_GRAPHICSEDITOR)
          Event code 425 (KEY_PRESENTATION)
          Event code 426 (KEY_DATABASE)
          Event code 427 (KEY_NEWS)
          Event code 428 (KEY_VOICEMAIL)
          Event code 429 (KEY_ADDRESSBOOK)
          Event code 430 (KEY_MESSENGER)
          Event code 431 (KEY_DISPLAYTOGGLE)
          Event code 432 (KEY_SPELLCHECK)
          Event code 433 (KEY_LOGOFF)
          Event code 439 (KEY_MEDIA_REPEAT)
          Event code 442 (KEY_IMAGES)
          Event code 576 (KEY_BUTTONCONFIG)
          Event code 577 (KEY_TASKMANAGER)
          Event code 578 (KEY_JOURNAL)
          Event code 579 (KEY_CONTROLPANEL)
          Event code 580 (KEY_APPSELECT)
          Event code 581 (KEY_SCREENSAVER)
          Event code 582 (KEY_VOICECOMMAND)
          Event code 592 (KEY_BRIGHTNESS_MIN)
          Event code 593 (KEY_BRIGHTNESS_MAX)
          Event type 2 (EV_REL)
          Event code 0 (REL_X)
          Event code 1 (REL_Y)
          Event code 6 (REL_HWHEEL)
          Event code 7 (REL_DIAL)
          Event code 8 (REL_WHEEL)
          Event type 3 (EV_ABS)
          Event code 32 (ABS_VOLUME)
          Value 0
          Min 0
          Max 668
          Properties:
            By running i meant : do the faulty keys respond ?
            • sirus555
              Just the arrow keys. Nothing else.
                Well ... Looks like the kernel is not getting any event from most of your keys 😕
