    On/Off Switch Possibility?
    onoff switch possibility
    • KwansuDude
      KwansuDude last edited by
      I have my rpi3 mounted inside an N64 Case.
      I purchased one of these:
      https://www.amazon.com/YCS-Basics-Cellphone-Charging-Extension/dp/B00B5HSC20/ref=sr_1_2?ie=UTF8&qid=1474066195&sr=8-2&keywords=micro+usb+extension
      to go inside the case and give it a cleaner plug in look on the outside.
      Would it be possible to splice this into that extension?:
      http://vintagewireandsupply.com/toggle-switch-brass-plated/
      Because you can shutdown the system from the ES menu I would just like the ability to switch the rpi3 off without having to unplug it
      everytime.
      I apologize if this is not the right section for this question but if anyone could help I would appreciate it.
      Thanks
        paradadf Staff last edited by
        Please, use the search function of the forum and the wiki before posting.
        https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
        • supernature2k
          supernature2k last edited by
          And please re-use the switches of N64 😉
