    Mupen64plus.cfg empty?
    mupen64plus.cfg empty
    4433
    • KwansuDude
      KwansuDude last edited by
      I have been following the installation instructions religiously.
      I have a raspberry Pi 3.
      Installed the latest version of Recalbox.
      Loaded it full of games.
      All systems work flawlessly except the N64.
      Probably a noob problem I am having.
      I am using original N64 Controllers with the dual mayflash usb adapter. I have been able to run the jstest and figure that out.
      I updated the InputAutoCfg.ini with the joystick being called a HuiJia USB GamePad and setting all the buttons properly.
      The next step is to edit the Mupen64plus.cfg so the controller configuration mode is set to manual.
      when I run
      nano /recalbox/configs/mupen64/mupen64plus.cfg
      it opens up but it says new file at the bottom and there is nothing there.
      If anyone can help or shed some light on my screw up it would be greatly appreciated.
      thanks,
      KwansuDude
      • nosfay
        nosfay last edited by nosfay
        Hi, the file you are looking for is recalbox/share/system/configs/mupen64/mupen64plus.cfg.
        But first, you have to add this line to recalbox.conf :
        n64.configfile=dummy
        KwansuDude 1 Reply Last reply Reply Quote 0
        • KwansuDude
          KwansuDude @nosfay last edited by
          @nosfay Thank you very much. That did the trick!
          Would you happen to have any advice on how to make the joystick more responsive?
          I've tried adjusting the analog peak without positive results.
          Thanks,
          KwansuDude
            Change the deadzone 🙂 That's something that will be made a little easier on the 4.1
            • KwansuDude
              KwansuDude @Substring last edited by
              @subs which direction should i change it?
                it's not a direction, it's a sensitvity setting for analog sticks
                • KwansuDude
                  @subs haha I got it. Thank you. The adjustment worked perfect!
