    Solved Moonlight: right stick not working correctly (Logitech F710)
    GamePad/GPIO/USB encoder
    moonlight gamepad right stick logitech f710
    7622
    • tuxophil
      tuxophil last edited by tuxophil
      Hi,
      I'm new to the whole moonlight thing and WOW! It's great! Mindblowing even.
      Until I noticed that on my right stick only the vertical axis is working. I tried Tomb Raider 2013 and Half-Life 2. In both games the right stick controls the camera, but only the vertical axis working, the horizontal one is simply ignored.
      As far as I can tell I set everything up correctly in recalbox's menus.
      Is there any moonlight-specific config that I have to amend/fix?
      Is this a known issue or should I file a bug report on github?
      I'm using recalbox 4.0-beta5 and Geforce Experience 3.0.5.22.
      Update: here's the config file share/system/configs/moonlight/mappingP1.conf that recalbox has auto-generated:
      # Device name = Logitech Gamepad F710
      # SDL2 GUID   = 030000006d0400001fc2000005030000
      # Event path  = /dev/input/event0
      btn_west = 307
      btn_east = 305
      abs_dpad_y = 17
      abs_dpad_x = 16
      reverse_dpad_y = false
      reverse_dpad_x = false
      abs_ry = 4
      abs_deadzone = 4
      btn_south = 304
      btn_start = 315
      reverse_ry = true
      reverse_rx = false
      btn_mode = 316
      abs_x = 0
      abs_y = 1
      reverse_x = false
      reverse_y = true
      btn_select = 314
      btn_thumbl = 317
      btn_tr = 311
      btn_north = 308
      btn_tl = 310
      btn_thumbr = 318
      abs_rz = 5
      abs_z = 2
      • tuxophil
        Hooray, I could fix it by modifying the config file to have the contents of the following mapping file: https://github.com/irtimmer/moonlight-embedded/blob/master/mappings/xbox360.conf
        tuxophil 1 Reply Last reply Reply Quote 0
        • tuxophil
          tuxophil @tuxophil last edited by
          https://github.com/recalbox/recalbox-os/issues/1051
            pad related configuration files are generated dynamically. I'd need your ~/.emulationstation/es_input.cfg to check something. Are you sure you mapped correctly your pad in ES ?
            edit : doh you're right : there is a small syntax error, my bad
            tuxophil 2 Replies Last reply Reply Quote 0
            • tuxophil
              tuxophil @Substring last edited by
              @subs
              So you no longer need the es_input?
              Anyway, I'm amazed at what a Raspi, a 6 year old PC and a GTX 750Ti can do 🙂
              • tuxophil
                @subs
                Just out of curiosity: Why doesn't recalbox autoconfigure the known gamepads? I just had a look at es_input.cfg and noticed that there are complete "profiles" for lots of known controllers. Wouldn't it be possible to have a complete out-of-the-box plug-and-play config?
                Or is that the intended behavior and it simply fails on my box due to some syntax error that you mentioned?
                  As i just said : configuration is generated upon launch of the emulator (we call it configgen). So whether you start retroarch, mupen moonlight, scummvm ... configgen generates the config files for the selected emulator.
                  Still, I don't get what you mean 😮 because it is already dynamically generated ... The more we fill the es_input.cfg (if you had to configure your pad, then yes I'm still interested into it to add it), the more recalbox is plug'n'play
                  • tuxophil
                    @subs
                    I'm sorry if my questions haven't been clear, I'll try to reformulate them 🙂
                    1. When I set up my current recalbox (4.0.0-beta5, clean install), at the first launch I was presented with an emulationstation-dialog prompting me to configure my controller, which I did. Now, in es_input.cfg I see lots of controllers that I don't own and then, at the end of it, my Logitech F710. I still don't know when and how this es_input.cfg is created, but since the system knows about many different types of controllers, I'm wondering why I had to do the initial controller configuration at all. Please note that this is not intended as a criticism, I'm simply wondering!
                      It seems to me that it would be possible to simply set up the controller automatically. The user would still have the possibility to reconfigure the controller if he needed to.
                    2. Is it a (minor) bug that the F710 is not automatically setup in emulationstation (and all emulators)? If so, is there some information I could contribute? Could it be that most/all of the other controllers in es_input.cfg were already present before the first boot and that my F710 only got added when I configured it?
                    3. (not a question, a confirmation) I do know that the mappings for the different emulators (not emulationstation itself) are created automatically based on my "main" config in Emulationstation.
                    Anyway, thanks for an awesome software product!
                    • tuxophil
                      tuxophil @Substring last edited by tuxophil
                      @subs said in Moonlight: right stick not working correctly (Logitech F710):
                      I think I've gained a better understanding now! I found this file: https://github.com/recalbox/recalbox-buildroot/blob/rb-4.1.X/board/recalbox/fsoverlay/recalbox/share_init/system/.emulationstation/es_input.cfg
                      and noticed that the Logitech F710 is not included by default!
                      Is this what you mean? Anyway, here's the relevant part of my es_input.cfg:
                      	<inputConfig type="joystick" deviceName="Logitech Gamepad F710" deviceGUID="030000006d0400001fc2000005030000">
                      		<input name="a" type="button" id="1" value="1" code="305" />
                      		<input name="b" type="button" id="0" value="1" code="304" />
                      		<input name="down" type="hat" id="0" value="4" code="16" />
                      		<input name="hotkey" type="button" id="8" value="1" code="316" />
                      		<input name="joystick1left" type="axis" id="0" value="-1" code="0" />
                      		<input name="joystick1up" type="axis" id="1" value="-1" code="1" />
                      		<input name="joystick2left" type="axis" id="3" value="-1" code="3" />
                      		<input name="joystick2up" type="axis" id="4" value="-1" code="4" />
                      		<input name="l2" type="axis" id="2" value="1" code="2" />
                      		<input name="l3" type="button" id="9" value="1" code="317" />
                      		<input name="left" type="hat" id="0" value="8" code="16" />
                      		<input name="pagedown" type="button" id="5" value="1" code="311" />
                      		<input name="pageup" type="button" id="4" value="1" code="310" />
                      		<input name="r2" type="axis" id="5" value="1" code="5" />
                      		<input name="r3" type="button" id="10" value="1" code="318" />
                      		<input name="right" type="hat" id="0" value="2" code="16" />
                      		<input name="select" type="button" id="6" value="1" code="314" />
                      		<input name="start" type="button" id="7" value="1" code="315" />
                      		<input name="up" type="hat" id="0" value="1" code="16" />
                      		<input name="x" type="button" id="3" value="1" code="308" />
                      		<input name="y" type="button" id="2" value="1" code="307" />
                      	</inputConfig>
                        That's it, thanks 🙂
                        To give you more details : es_input.cfg is the file where emulationstation stores the pads configuration. And it's filled with quite much data that allows us to configure almost any emulator
                        I made a typo for moonlight, patch sent to digitaLumberjack
                        tuxophil 1 Reply Last reply Reply Quote 1
                        • tuxophil
                          @subs
                          Ah ok, thanks! I'm glad I could make a tiny contribution 🙂
