    Is there a way to change the hotkey combinations ?
    hotkey combinations
    5279
    • Fudoh
      Fudoh last edited by
      Quite often I find myself entering the Retroarch config menu by mistake (usually when playing some action title and preparing to use the save state function).
      I'm looking for a way to put the menu call for Retroarch on some other button than Hotkey+B.
      Any hints are highly appreciated! Thanks in advance 🙂
        I wouldn't bet, but i think it's a retroarch thing ... Anyway, once in the menu, you can still save the state 😉
        • Dinierto
          Dinierto Banned last edited by
          I think it would be nice if there was an option to disable the Retroarch hotkey. It's too easy to get into trouble for basic users
            voljega Banned @Dinierto last edited by
            @Dinierto I think it would be nice if you read the manual
            Dinierto 1 Reply Last reply Reply Quote 0
            • Dinierto
              Dinierto Banned @voljega last edited by Dinierto
              @voljega I did, I don't remember any mention of disabling that hotkey but I'll check again.
              EDIT: I still don't see it in the manual. I must be looking in the wrong place.
                Substring @Dinierto last edited by
                @Dinierto maybe get a closer look at the recalbox.conf ? 🙂
                • Dinierto
                  Dinierto Banned @Substring last edited by
                  @subs said in Is there a way to change the hotkey combinations ?:
                  Is that what they're referring to in this line:
                  nomenu -> cannot popup the emulator menu
                  I assumed that was the menu in ES (when you press start)
                    @Dinierto that's it 🙂
                    • Dinierto
                      Oh okay thanks!
