    emulators resolution 800x600
    Your recalbox
    800x600
    4246
    • kelevra981
      kelevra981 last edited by
      hello guys , I state that it is only recently that I attempt with emulations , I bought a raspberry ft 2 and an LCD panel 8 " maximum 800x600 60hz resolution.
      I managed to start recalbox , the screen can be seen well, when I start the emulators the screen dark and I can not support the resolutions , it happens with all emulators except for the nintendo 64 who apparently has already set the base 800x600 , the fact is that I can not access to the configurations of all the others .
      I tried to insert a global setting with DMT9 but I always have the same problem
      can you help me ? thanks
      sorry for my english, i have used a google translate
        hey @kelevra981
        is your TFT screen a HDMI one ?
        Anyway, setting global.videomode=default in the recalbox.conf is fairly enough, most of times. There are quite some infos on the wiki about video settings
        • kelevra981
          yes is a TFT HDMI
          https://shop.pimoroni.com/products/hdmi-8-inch-lcd-screen-kit-800-600
          i setting whit global.videomode=default but emulator dont work, i no have idea 😞
          • kelevra981
            my setting now:
            #hdmi_safe=1
            disable_overscan=0
            hdmi_group=2
            hdmi_mode=9
            hdmi_drive=2
            hdmi_force_hotplug=1
            #sdtv_mode=2
            #dtoverlay=lirc-rpi
            boot_delay=3
            avoid_safe_mode=1
            kernel=zimage
              @kelevra981 dude, you're messing settings. I said the global.videomode is in the recalbox.conf, not the /boot/config.txt.
              • kelevra981
                sorry, i'm a noob whit lynux, how I can do to open recalbox.conf?
                  Read https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
                  Open in ssh with putty or winscp if you use windows https://github.com/recalbox/recalbox-os/wiki/acces-via-WinSCP-(FR)
                  Robsdedude 1 Reply Last reply Reply Quote 0
                  • Robsdedude
                    Robsdedude @acris last edited by
                    @acris Gentle Hint: The first link sends me to a "create new wiki page" page. My browser tells me there could be a XSS-Attempt. I thought this could be of interest to you. (Using FF 48.0, works in Chromium 51.0.2704.79).
                    Dev console sais:
                    Content Security Policy: Directive 'frame-src' has been deprecated. Please use directive 'child-src' instead.
                    Content Security Policy: The page's settings blocked the loading of a resource at about:blank ("base-uri https://github.com").
                    May also be a github bug. Couldn't track it down.
                      I have no problem with 2 links. Theses links exist.
                      101.0k
