    Joytick Fighting Commander 4 Hori
    GamePad/GPIO/USB encoder
    joytick fighting commander hori
    3943
    • Fábio Nascimento
      Fábio Nascimento last edited by
      Hi,
      I'm looking for a joytick that has 6 frontal buttons instead of the standard 4 buttons, like the old megadrive joysitcks because I play only fight games like KoF, MvsC, SSF/MK, etc..
      I found this one: https://www.amazon.com/PS3-Accueil-JEUX-VIDÉO-PlayStation-Accessoires/dp/B017QORK8W
      But since it's kinda expensive compared to other models, is there a way to know if this joytick is compatible with recalbox/emulators?
      Thanks!
        Hello @Fàbio Nascimento
        you have to choose a gamepad in compatibility list : https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)#pad-controller (recommended)
        Fábio Nascimento 1 Reply Last reply Reply Quote 0
        • Fábio Nascimento
          Fábio Nascimento @acris last edited by
          @acris Yeah I know that, but there are some hori joysticks that are compatible:
          Xbox 360 / PC HORI Fighting Stick EX2 USB ✅
          HORI Fighting Stick MINI 4 for PS4
          I can't find the exact same model as mentioned on the list.
          I was hoping that someone already tried the Joytick Fighting Commander 4 and knows if it is compatible.
          Thanks anyways!
            @Fábio-Nascimento if you are lucky, the PCB inside is the same as other compatible pads, so it's just a different skin on the pad itself. If you are not lucky, it's another PCB. We honnestly can't know, unless someone tries. My guess would be that any firm tries to minimize expenses for maximum profit, so they may simply have changed the skin of an existing pad. But I can't promise
            • Fábio Nascimento
              Fábio Nascimento @Substring last edited by
              @subs cool, thank you mod!
              Igor Luiz Ali 1 Reply Last reply Reply Quote 0
              • Igor Luiz Ali
                Igor Luiz Ali @Fábio Nascimento last edited by
                @Fábio-Nascimento I have one Fighing commander and I can test to tell you if work or not...
                • Fábio Nascimento
                  Fábio Nascimento @Igor Luiz Ali last edited by Fábio Nascimento
                  @Igor-Luiz-Ali that would be awesome! thanks in advance!
                  Do you like this joystick? I want it because of the 6 frontal buttons!
