    PS3 DUALSHOCK3 with ASUS BT400 not working
    GamePad/GPIO/USB encoder
    ps3 dualshock3 asus bt400
    5873
    • bastibasti
      bastibasti last edited by
      Hi.
      New setup - RPI3, BT400 & dualshock3. All brand new off amazon - the controller is labelled sony. However the box doesnt recognize the controller. When connecting via USB, the controller blinks, after that it doesnt seem to connect via BT. Any Idea?
      Recalbox is 4.0-beta5
      lsusb
      Bus 001 Device 010: ID 0b05:17cb
      hciconfig -a hci0
      hci0: Type: BR/EDR Bus: USB
      BD Address: 5C:F3:70:72:EE:DC ACL MTU: 1021:8 SCO MTU: 64:1
      UP RUNNING PSCAN
      RX bytes:1232 acl:0 sco:0 events:71 errors:0
      TX bytes:1088 acl:0 sco:0 commands:71 errors:0
      Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
      Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
      Link policy: RSWITCH SNIFF
      Link mode: SLAVE ACCEPT
      Class: 0x400100
      Service Classes: Telephony
      Device Class: Computer, Uncategorized
      HCI Version: 4.0 (0x6) Revision: 0x1000
      LMP Version: 4.0 (0x6) Subversion: 0x220e
      Manufacturer: Broadcom Corporation (15)
      anything else how i can debug this?
        Yeah, check dmesg and make sure that the manufacturer of your device is sony, not gasia or shanwan
        • bastibasti
          bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0b05-17cb.hcd failed with error -2
            Hello
            your dongle is not compatible with recalboxOS.
            Try to find a firmware, may be this soluce :
            https://workingninja.com/blog/installing-asus-bt400-raspberry-pi-raspbian-wheezy
            • bastibasti
              Hi,
              i managed to get the firmware... it gives no error message during modprobe now
              [ 1.978280] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
              [ 2.092041] usb 1-1.4: New USB device found, idVendor=0b05, idProduct=17cb
              [ 2.092054] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [ 2.092060] usb 1-1.4: Product: BCM20702A0
              [ 2.092067] usb 1-1.4: Manufacturer: Broadcom Corp
              [ 2.092073] usb 1-1.4: SerialNumber: 5CF37072EEDC
              [ 2.154156] Bluetooth: Core ver 2.20
              [ 2.154282] NET: Registered protocol family 31
              [ 2.154290] Bluetooth: HCI device and connection manager initialized
              [ 2.154326] Bluetooth: HCI socket layer initialized
              [ 2.154343] Bluetooth: L2CAP socket layer initialized
              [ 2.154379] Bluetooth: SCO socket layer initialized
              [ 2.167827] usbcore: registered new interface driver btusb
              [ 2.173567] Bluetooth: hci0: BCM: chip id 63
              [ 2.174563] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
              [ 2.269269] bcm2835-rng 3f104000.rng: hwrng registered
              [ 2.269512] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
              [ 2.427590] random: nonblocking pool is initialized
              [ 2.693981] EXT4-fs (mmcblk0p8): couldn't mount as ext3 due to feature incompatibilities
              [ 2.694703] EXT4-fs (mmcblk0p8): couldn't mount as ext2 due to feature incompatibilities
              [ 3.062671] Bluetooth: hci0: BCM20702A1 (001.002.014) build 1467
              [ 4.285955] EXT4-fs (mmcblk0p8): recovery complete
              [ 4.289497] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
              [ 4.778287] cfg80211: Calling CRDA to update world regulatory domain
              [ 6.771505] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              [ 6.771517] Bluetooth: BNEP filters: protocol multicast
              [ 6.771531] Bluetooth: BNEP socket layer initialized
              [ 6.817074] Bluetooth: RFCOMM TTY layer initialized
              [ 6.817097] Bluetooth: RFCOMM socket layer initialized
              [ 6.817111] Bluetooth: RFCOMM ver 1.11
              [ 7.938303] cfg80211: Calling CRDA to update world regulatory domain
              [ 10.271462] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
              [ 10.271488] Bluetooth: HIDP socket layer initialized
              • bastibasti
                [1_1472236621475_BCM20702A1-0b05-17cb.hcd](Uploading 100%) [0_1472236621474_BCM20702A1-0b05-17cf.hcd](Uploading 100%)
                in case you want to add the firmware to the next build
                • Nachtgarm
                  Nachtgarm last edited by Nachtgarm
                  Moved the topic into the correct category
                  Wir können auch Deutsch @bastibasti 😉 Dazu dann aber bitte HIER die richtige Kategorie für Fragen auswählen.
                    Substring @bastibasti last edited by
                    @bastibasti dude, could you tell us in hwhich folder exactly you dropped it ?
                    adiif1 1 Reply Last reply Reply Quote 0
                    • adiif1
                      adiif1 @Substring last edited by
                      @Substring refresh?
                        Substring @adiif1 last edited by
                        @adiif1 necroing topics ?
