    Solved only arcade fba games are working.
    Emulator Arcade/PC/Console
    arcade fba are working
    • Fattori
      Fattori last edited by
      I really look for someone with the same problems but i don’t find a thread with the similar issues.
      I just got my recalbox in a raspberry pi3 model b (1.2GHz 64-bit quad-core ARMv8 CPU1.2GHz 64-bit quad-core ARMv8 CPU)
      a 64gb Micro SD card class 10
      and i was trying to play street fighter 3 but the game was kind of slow, so i tried to change roms, installed a lot of different rom and none of is worked.
      I update the game list, and also update the system on the internet, everything worked but not the cps3 games
      I don’t now what i did different but now no emulator work, it tries to boot the game, the screen goes black and then goes back to the menu. the strange thing is that the only emulator that are working is the lib arcade games, and when i start a game it has some really bad filter (the games look like they are played in old arcade monitors) and the commands to exit the game stopped working.
      Is there a way reinstall the recalbox without loosing my roms?
      Is there any idea of what i did wrong? i transferred the new roms to the recalbox through a usb flash drive using the lodi file manager i guess i deleted something there while deleting the older roms
      Any clues of what should i do?
        voljega Banned @Fattori last edited by voljega
        @Fattori well use your file manager to make a copy of your roms on your usb drive (I would advise to always keep a copy aside your recalbox)
        Then do a fresh clean install
        You can also directly use an usb drive instead of copying roms on the sd, see wiki.
        Please also read the two pages about arcade games
          paradadf Staff last edited by
          For cps3, turn off the rewind function on the emulator.
          • Fattori
            @voljega said in only arcade fba games are working.:
            Thanks! that worked for me!
            and i turned off the rewind function and everything is perfect!
            101.0k
