    PS1 - Tekken 3 black scanlines
    ps1 tekken scanlines
    4997
    • pdaboy
      pdaboy last edited by
      I'm getting black scanlines on Tekken 3. I've tried all the options in the menus but nothing seems to get rid of them. Does anybody know how to get rid of them. Thanks.
      • pdaboy
        This is an example of it attached.
        • nickdj
          nickdj last edited by
          Have you tried a different roms. The one I use is from the following link. http://www.freeroms.com/roms/psx/tekken_3.htm The only issue I get is the occasional stutter/broken audio when there is a dust effect on the screen. Hope this helps.
          RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
          • pdaboy
            Hi Nick I've tried several different roms of Tekken 3 and get the same effect. Other games display the lines but it is not as noticeable as it is in Tekken.
            • digitaLumberjack
              Hi, Weird, did you do some modifications anywhere ? Shader ? Resolution ?
              • pdaboy
                None that I know of. The only changes that were made were to the config file so I can use composite instead of hdmi. This issue also occurs on hdmi.
                • digitaLumberjack
                  Rpi1 or rpi 2 ?
                  • pdaboy
                    rpi1 model b 512mb version
                    • nickdj
                      Does the same thing happen with a fresh install of Recalbox? Do you get the same results with the latest version (3.2.11) and an older version (e.g. 3.2.4)?
                      • pdaboy
                        I've tried a fresh install and still get lines but not as many as on the other install. I'm going to try it on 3.2.11 I've also got my ps1 games down from the loft and going to rip my Tekken 3 pal disc and use that rather than the downloaded bin files.
                        • pdaboy
                          Just got a pi 2 and the problem is not on there so must be an issue on the pi 1.
                          • digitaLumberjack
                            Ok good to know...
