    RP3, can not find bluetooth gamepad (8bitdo zero)
    GamePad/GPIO/USB encoder
    rp3 find bluetooth gamepad 8bitdo
    4928
    • peacemoon
      peacemoon last edited by
      I have just installed recalbox v4.0.0 beta 5 on my rp3. Everyting works fine until I try to connect rp3 with my 8bitdo zero. The rp3 found no controller (I started the controller already (using Start+R)) .
      here are some logs:
      lsmod
      Module Size Used by Not tainted
      btbcm 4047 0
      ipv6 325729 30 [permanent]
      hidp 12425 2
      bnep 9932 2
      bluetooth 307447 13 btbcm,hidp,bnep
      uinput 6897 0
      snd_bcm2835 18527 2
      snd_pcm 70976 2 snd_bcm2835
      snd_timer 18137 1 snd_pcm
      snd 49082 6 snd_bcm2835,snd_pcm,snd_timer
      evdev 9707 2
      brcmfmac 166680 0
      brcmutil 5425 1 brcmfmac
      cfg80211 396344 1 brcmfmac
      rfkill 14498 4 bluetooth,cfg80211
      bcm2835_gpiomem 2759 0
      bcm2835_rng 1666 0
      uio_pdrv_genirq 2869 0
      uio 7487 1 uio_pdrv_genirq
      I try to enable bluetooth using rfkill, but don't know how to install rfkill on arch (I only have some exp with ubuntu).
      Anyone know how to enable bluetooth on my rp3 running recalbox?
      Thanks
        Hello
        you need a bluetooth dongle wih rpi3.
        Since beta 2 :
        Added rpi3 support (without bluetooth)
        • peacemoon
          oh ok. I didn't know that. Thank you for your answer. Any plan to support the built-in bluetooth of rp3 in the future versions?
            Bluetooth integrated in recalbox 4.1
            Please check changelog in github
            elviscosentino 1 Reply Last reply Reply Quote 1
            • elviscosentino
              elviscosentino @acris last edited by
              @acris Where is Recalbox 4.1.0?
              github has only 4.0.0 beta5
                No recalbox 4.1.0 for now, will be available a few months.
