    implementing a .so file
    gameboy core gpio link
    • wahlross
      wahlross last edited by
      I had the idea to connect a game boy link cable port to the gpio pins, so that i can build up a link-cable connecton between an original gameboy and the emulator. The hardware shouldn't be a problem, but software is giving me some problems.
      I lookt into the game boy programming manual (http://www.chrisantonellis.com/files/gameboy/gb-programming-manual.pdf) and the source code of the tgbdual emulator (https://github.com/libretro/tgbdual-libretro) and i think i know what changes i have to make and i figured out how to recompile the code into a ".so"-file.
      Here comes the problem: i don't know how to implement this .so file into my recalbox system and choose it as standart gb emulator.
      i hope some of you can help me with that.
      • MikaXII
        MikaXII Staff last edited by MikaXII
        I don't understant this package is already in recalbox github-link.
        What do you want exactly ?
        Edit : if you want update sources you should make a patch.
        mika@recalbox.com
          Hello
          link may be https://github.com/recalbox/recalbox-os/wiki/Play-with-two-GameBoy-(EN)
